Results 1 to 7 of 7
    Jul 17 2008
    1400 RPM idle...
    recently had a bad MAF, car was going limp and idled like shit/stalled a lot. changed that out, fixed nearly all my problems however now the car idles really high, around 1400 RPM, but around 800 with the AC on... I'm thinking bad O2 sensor or something, though no cel's on. Anybody experienced this before?
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: 1400 RPM idle...
    Vacuum leak? Bad PCV valve?
    Jim
    I Do Werk.
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    ^^^X2
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Aug 01 2008
    levittown
    do you have a chip? had same problem would idle high then idle good with ac on. used vag com to reset the throttle adaption and fixed the idle
    Jul 17 2008
    10-4, thanks guys
    Jan 25 2006
    A4 2.0T
    MD
    Try the TBA, please post back if it works.
    Established Member Two Rings CaddieManAudi's Avatar
    Jun 21 2008
    1998.5 1.8T QM
    Daytona Beach, Florida
    I had a high Idle speed before, but I did some work that involved the ECU removal and when you disconnect the ECU it cause the car to relearn its settings. I went from about 1300 rpms to 850sih. When removing and reinstalling the ECU be sure to let the car sit (with your door open) after turning it on and wait for the Ding to stop (typically around 1-2 min) and it should have readjusted by then to its normal Idle Speed.
