Results 1 to 9 of 9
    Veteran Member Two Rings Vinchenzo's Avatar
    Sep 26 2004
    Your girlfriend's car 8-)
    Bama Beotch!! ROLL TIDE!
    Need help trying to figure out what is wrong with my car...
    Okay, to make the long story short, my car starts shaking like the wheels are out of balance ONLY when it rains. I've had my wheels balanced, aligned, and fixed the camber on it when I lowered my car with H&R coilovers. I had my wheels/tires balanced again thinking that would fix the problem. When it's dry outside, it rides fine. But when it starts raining and I hit the ruts of water on the road, it starts shaking like the wheels are out of balance and my top speed is only 65mph. Anything over that, my car starts shaking. UGH!! It is so frikkin' annoying. Just to give a background on what I have for suspension....H&R coilovers, upgraded front and rear sway bars, snub mount. Thanks in advance.
    S4 gone...still an AUDI enthusiast...now have an EVO IX.
    FP Green Turbo, Greddy TBE, GSC S2 cams, Spark Tech COP, ETS UIP, Omni 4 bar, Grimmspeed 3 port EBC, Synapse Synchronic BOV, Bushur Mini Battery, Buschur Intake, Turbosmart 40mm Comp-Gate WG, 255 Walbro, FIC 1100 High Impedance, Russell SS Brake lines, Megan Coilovers, POS ACT ttp clutch
    Dec 28 2005
    NY/NJ
    Re: Need help trying to figure out what is wrong with my car...
    simple answer: if you're wheels have a reverse lip on them, water stays in the barrel and as you drive, it causes the vibration
    Current: 2024 SQ7, 2021 RS5
    Established Member Two Rings tileg's Avatar
    May 01 2008
    Philadelphia
    whats a reverse lip?
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    ^^What he said. I get puddles on the inside barrel and the rear lip, you get used to it. It goes away afterall the water is gone
    Dec 08 2006
    Jersey
    Quote Originally Posted by lk1122 View Post
    Established Member Two Rings BlackB7Quattro's Avatar
    Apr 05 2006
    '06 A4 / '96 Cherokee
    Manchester, NH
    Quote Originally Posted by Kyokio View Post
    Ding Ding Ding
    Sep 26 2004
    Thanks for the input guys. Just curious though, while I'm driving, shouldn't the water wash out and eventually start driving normal? For instance, I was driving where it was raining and my car was doing it's annoying thing, then the rain suddenly stopped and it was still doing it. One of my friends mentioned to me that one of my wheels might be warped. But if it was warped, wouldn't it ride like crap all of the time and not just when it rains? Is there something I can do to fix this if it is water trapping in the barrel?
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    The problem will exist until the water has dried. Maybe waxing your rims will help the water exit faster.
    Sep 26 2004
    I'll give that a try. Thanks again y'all for your feedback. I was scared thinking that maybe my axle was loose or something and moving back and forth when it came in contact with some force. Thanks again.
