Results 1 to 6 of 6
    Veteran Member Three Rings audiman27's Avatar
    May 30 2008
    Port Saint Lucie, FL
    19" +45 wheels need spacers?
    I just ordered some 19" wheels that are 8" wide and have +45 offset. I was told I might need spacers to clear the brakes. If so, anyone know how thick and do I need them all around? I'm planning on running 235/35/19 on 02 sport suspension, hopefully no rub!
    Jun 14 2005
    Anaheim, CA
    Re: 19" +45 wheels need spacers?
    What kind of brakes are you running? +45 is really sunken in for a 8.0" wheel. People usually do 19x8.0 +35.
    -Charles@VMRWheels
    www.vmrwheels.com
    Brandon @ VMR Wheels
    May 30 2008
    Brakes are stock. It's a 02 A4. If I do a 10mm spacer, that would bring it to +35?
    Veteran Member Four Rings DeanUW's Avatar
    Feb 22 2007
    Lots of stock parts :-)
    Auburn, WA
    You should run 15mm spacers, it all depends on how sunkin you want to be, those +45's will be sunk like a battle ship! I run 19x8.5 +35 with 8mm spacers. Perfect!!!
    Deanophotography.com | The A4 (Updated 3/1/10)
    REVO Tuned GTRS Eliminator
    Caractere | Evolution Racewerks | Southbend | STĂSIS | ATP | QTP | Magnaflow | Samco | OEM | VMR | Defi | TurboXS Dtec w/ Gameboy
    Mar 27 2005
    The Cold North
    Quote Originally Posted by audiman27 View Post
    why would your order wheels knowing that they may not fit properly?
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    May 30 2008
    I was going to order 18 x 8.5 ET35 wheels, then I decided to go to the 19" wheel instead, thinking the offset was the same. Like an idiot I didn't read the entire listing. I just want to maintain the factory poke. So 15mm spacers would be good?
