Results 1 to 8 of 8
Thread: spark plugs????
    Senior Member Two Rings xmoox's Avatar
    Aug 11 2008
    2000 audi s4
    Portland OR
    spark plugs????
    Im looking to change my spark plugs soon. I have an Audi s4 running stage 2. i was looking at pulsars are they any good? are there claims for more horse power true. i have ngk spark plugs right now. I'm just curious which spark plug would be the best and give me the most horse power. i don't think my ngk right now are the good ones they have the green lettering instead of the blue.
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    Re: spark plugs????
    consensus around here says that bosch side fires are the best. Someone was going to try out the Pulsars but never posted update on how they were.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Aug 11 2008
    2000 audi s4
    Portland OR
    Re: spark plugs????
    okay ill try them yea i saw the post for the pulsar plugs and how they melted in an evo so im kinda hesitant to try them in my s4 but they look like they perform better. ill try the bosch if anyone says pulsars are bad.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: spark plugs????
    Quote Originally Posted by xmoox View Post
    ngk's are good depending on the heat range you get. im running bkr6eix's (iridiums)
    i love em. never had a problem, and my car is stage 3..not that that matters but .shrugs.
    Apr 13 2008
    Tennessee
    Re: spark plugs????
    NGK BKR6E runs fine for me
    only heard bad things about pulsar whatnots
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    Re: spark plugs????
    Quote Originally Posted by quickaudi View Post
    thats what i run, just changed them, no codes *yet*
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
    Aug 06 2008
    Canadia
    Re: spark plugs????
    i'm running NGK aswell, 6 heat range, if your chipped a 7 heat range might offer some benefit as it runs cooler and the chip most likely makes things run hotter than stock.
    I'd stay the hell away from Bosch, had nothing but problems with their products. from H4 headlight housings cracking (thin glass) to O2 sensors failing after 5000KM to the ceramic on a spark plug spinning freely of the rest of the plug, and the +4 plugs fouling like crazy.
    besides, OEM is NGK.
    Veteran Member Four Rings lrg8683's Avatar
    Nov 01 2005
    S4
    VA
    Re: spark plugs????
    ngk bkr7e
    -Luis
