Results 1 to 3 of 3
    Established Member Two Rings hmmd's Avatar
    Feb 07 2007
    2005.5 A4 2.0T quattro
    el centro, california
    headlight flickering
    my right headlight is flickering, before it used to do it every once in a while, now it seems like it's always doing it, and sometimes it seems like it goes out then comes back on again, and i'll get the "right dipped headlight" message every now and again (which goes away if i turn off the lights then turn them back on). i have the bixenon headlights with the adaptive front lighting and the car is lowered. the dealership said it could be because the car is lowered, but the car has been lowered a lot longer than i've had this problem. anybody experience something similar? thanks in advance
    ha haa! dangly parts
    Jan 01 2008
    Long Island NY
    Re: headlight flickering
    its the ballast. should be covered under warranty.
    Senior Member Three Rings Bryson's Avatar
    Apr 07 2008
    2006 B7 A4 2.0t (not s-line)
    la quinta, California
    hey mine have done some flickering aswell, could be the bulbs getting old. HID bulbs flicker as they start dying. the ballast is a possibility aswell
