Results 1 to 4 of 4
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    any idea where i can tap a RPM wire?
    need it for some data logging
    Veteran Member Three Rings drexplode's Avatar
    Jul 19 2007
    2016 M3 - maximum hooligan
    Michigan
    Re: any idea where i can tap a RPM wire?
    i know our engine calibration technicians at work use a smart tach which clamps around the ignition coil wires and feeds into a RPM box.
    If you have a VAG-COM, shouldnt that allow you to read engine speed? I know i have a program on my work laptop called DIAGRA that allows me to plug into the OBDII sensor and monitor a variety of variables/outputs.
    "A turbo boost gauge the size of a fat spaniels face! - Jeremy Clarkson
    Veteran Member Four Rings DeanUW's Avatar
    Feb 22 2007
    Lots of stock parts :-)
    Auburn, WA
    What are you data logging with? EBC? Why not just use the VAG Com?
    Deanophotography.com | The A4 (Updated 3/1/10)
    REVO Tuned GTRS Eliminator
    Caractere | Evolution Racewerks | Southbend | STĂSIS | ATP | QTP | Magnaflow | Samco | OEM | VMR | Defi | TurboXS Dtec w/ Gameboy
    Mar 09 2005
    Santa Clara, CA
    Quote Originally Posted by drexplode View Post
    Quote Originally Posted by DeanUW View Post
    I can pull a RPM signal off my cig lighter, is that accurate though? I won't be using the vag-com for this particular instance...this will be for my traqmate
