Results 1 to 17 of 17
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    Edge of tire wearing down.
    As I was changing my oil the other day I noticed that the inside edge of my front drivers side tire was worn down. I just had it brought in 4 months ago for an alignment and suspension inspection. They replaced one of the control arms on the passenger side and aligned it. They said that whomever aligned it last time did a horrible job and that it was way off. Well after noticing the tire wear I brought it in for an alignment check at a different place this time cause my normal spot was closed, and all was still perfectly aligned and all the suspension components were in top shape. is their anything else that could be causing the wear? I am lowered on eibach's paired with bilsteins but I am not as low as most people on here. It is possible that it was already wore due to the previous botched alignment, and I just now noticed it. Just wondering if their is anything else you think I should check. Thanx for any input.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Edge of tire wearing down.
    Tire pressure maybe? Check that. It sounds like a toe issue.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Check tire pressure first, you may have run a little un-inflated for a time. Second, lowered cars get negative camber, leading to inside tire wearing.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Camber alone increases tire wear very little. Toe will scrub the rubber right off the tires and kill gas mileage.
    Are there any signs of uneven wear, cupping, or other irregularities?
    Jim
    I Do Werk.
    Veteran Member Four Rings A4 Effort's Avatar
    May 28 2007
    '99 A4 2.8 / '07 A4 S-Line Avant / '09 A4 S-Line 2.0
    Mt. Airy, MD
    ^+1 - incorrect toe adjustment will wear on your tires faster
    | 2007 Ibis Ti S-Line Avant | APR Stage 2+ | APR HPFP | 034 HFC | Forge DV | Stasis Exhaust | KW V1 Coilovers | SPC Adjustable Control Arms | 19" MRR GF6s | 034 TIP | 034 Sway Bar & End-Links | K&N Drop-In | Deval CF Front Splitter | Relak CF Sideskirts | S4 Recaros | TT-Sline MFSW | P3 Vent Gauge | RS4 Grille | RS4 Fog Grille Mod | RS4 Pedals | RS6 Shift Knob | OEM+
    Deactivated Four Rings
    Nov 19 2006
    MMM
    Same thing happened to my car, I believe it to be the bearing.
    Dec 05 2007
    Quote Originally Posted by MikeWasHere05 View Post
    x2. I was also going to suggest it to be the wheel bearing. But it could always be something else.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Wheel bearing get loud when they go bad, he'd know.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    May 12 2007
    MN
    Quote Originally Posted by nebone22 View Post
    Yeah I'm pretty sure it's not the bearing, I have detected bad bearings on my parents vehicle before so I know the noise that goes along with them. As far as the tire pressure, it's all set to the recommended 32 from the fuel door, And I check it often. Also the car rides very smooth, the tires don't feel to be fighting each other.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Is your car lowered? I molested my inner tire walls after a trip to Waterfest Last year after I lowered the car. Alignment afterwards seemed to solve that as my winter tires never had an issue with many miles on them. You won't feel the wheels fight one another, but there is definately a sign of that. Get an alignment if you want to save the tires.
    Mar 09 2004
    nw michigan.
    Usually but not always. My wife's outback has a bad bearing and it is dead silent. The only sign is a vibration at 55 mph. Keep it under 50 and it is nice and smooth. Brand new wheels and tires too.
    I've never run as low as 32. 36 at the lowest, 42 for road trips.
    Jim
    I Do Werk.
    May 12 2007
    MN
    The alignment is good, It was just checked on Tuesday. I guess I'll go for a drive later and see if I notice any vibration at higher speeds.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    I got new wheels and tires and going to NYC tonight so I'm pumping them up to 42 psi.
    May 12 2007
    MN
    Whoops I meant I have mine at 38 not 32 like I said earlier, Not sure what I was thinking. Also I went for a drive, got up to about 85 and their was no vibration. Hopefully the wear was just from the old botched alignment I got last year.
    Mar 09 2004
    nw michigan.
    Quote Originally Posted by generik777 View Post
    Rotate front to back and see if that corner exhibits the same type of wear again.
    The vibration thing is kinda a one-off. Her car is the only one I've ever heard of acting like that.
    Jim
    I Do Werk.
    Senior Member Two Rings CycloSteve's Avatar
    Apr 23 2008
    My Own Private Idaho
    ^^x2
    Doh, onemoremile types faster than me...Do a front-to-rear tire rotation, and see if the new tires on the front go from OK to having the same odd wear pattern. Easy DIY, and if all looks well in a few thousand miles, then you are set.
    2006 A4 2.0T Quattro Avant Manual - Let the mods begin
    2006 A4 2.0T Quattro Sedan Manual - Son's 2nd A4, well on the path to Stage 2+
    1998 A4 2.8 Quattro Avant Manual - PES G2, Milltek Exhaust, DTM 18x8's, Hotchkiss Swaybars, StopTech Stage II, PSS9 Coilovers, APR Snub, Podi, JHM SSK, Unorthodox LWFW, South Bend Stage 3
    Non-Audi Vehicles include multiple Landcruisers, Cayenne, BMW 335, trials and dirt bikes, M3 Euro-delivered from factory - SOLD and missed
    May 12 2007
    MN
    Quote Originally Posted by onemoremile View Post
    Good idea, You're a smart man. I feel dumb for not thinking of that.
