Results 1 to 10 of 10
Thread: APR BiPipe
    Senior Member Three Rings PMR2.7t's Avatar
    Mar 26 2008
    2003 A6 2.7T
    Harwood Heights, IL
    APR BiPipe
    Dos anyone have a APR BiPipe installed ???? The this bipipe give extra performance ????
    How many of you guys recommend changing the bipipe????
    Veteran Member Four Rings blkrhyno's Avatar
    Mar 24 2008
    2004 audi a6 2.7T 2005 Nissan
    Brooklyn, New York
    Re: APR BiPipe
    I read that it really isn't a need to change them unless you are going stage 3. Don't really know, just something I read.
    Veteran Member Four Rings Gigi's Avatar
    Jan 23 2006
    2004 Audi A6 2.7T, 1999 Jeep W
    Charlotte, NC
    Re: APR BiPipe
    I have it on my car and am happy with it. It is not a performance upgrade, more for reliability long term as the OEM TBB is a weak point expecially for modded cars. Instead of just getting a stronger TBB (SAMCO), this also replaces the front plastic v-looking pipes that botl up to the TBB.. so it is ONE piece made of hard material... no cracking, flexing... more constant flow. IMO
    Have a great day, Brice
    99 Jeep TJ, 4" lift, Mikey Thompson rims & tires
    http://i157.photobucket.com/albums/t...i/photo-22.jpg
    http://i157.photobucket.com/albums/t...20TJ/Jeep2.jpg
    SOLD: 04 Blue [B]A6 2.7TStage 2 +: Many mods
    Mar 26 2008
    2003 A6 2.7T
    Harwood Heights, IL
    Re: APR BiPipe
    So this should be a nice upgrade when i get my car chiped this week ...
    ECS has this APR - Bi-Pipe Kit **Includes 2 New Forge 007P's on sale so im thinking about getting it .....
    Feb 01 2008
    Missouri
    Re: APR BiPipe
    just buy a silicone tbb. I mean i love the idea of the bi-pipe, but i have heard the can break too. I would always take the cheaper option if possible.
    Veteran Member Three Rings 04A6SLine's Avatar
    Oct 16 2007
    Brooklyn NY
    Re: APR BiPipe
    Quote Originally Posted by PMR2.7t View Post
    dam it also include two DV.... go for it...
    Senior Member Three Rings skiroad'r's Avatar
    Apr 21 2008
    2002 allroad Tip, 2005 Mazda 6 Wagon 5MT
    Central New Jersey
    Re: APR BiPipe
    at least on the allroad, it is not a direct fit -- People have talked about modifying it slightly to get it to fit.
    '02 allroad 2.7T Tip
    ASP Flash, 034 Snub Mount (DIY), VAST EFK (DIY), H-SPORTS (Hard)
    Anrott Gen II Front Airsprings (DIY), Magnaflow mufflers with 3.5" tips
    Summers: Yokohama Avid W4S/RS6 Reps
    Fog DRL's, Toggable 628 Relay, Tip Override Recode, Remote Window Recode, Clear Corners (DIY)
    Timing Belt DIY (at 60K miles), Tiptronic Drain & Refill Service DIY (at 62K miles)
    GET OEM PARTS HERE: http://www.europaparts.com/
    Senior Member Two Rings Longbeach24's Avatar
    Aug 08 2007
    B7 Ibis White 6MT
    RI
    Re: APR BiPipe
    I went Samco and 710N. For the price, you can't beat it. ~$160 vs. $544
    Jan 23 2006
    Charlotte, NC
    Re: APR BiPipe
    Nice upgrade but as said above not required, most are happy with the SAMCO TBB.. personal preference... ECS usually sells it also with the 710 DVs which is a more affordable package.... 710s are enough at least til yuo go stage 3 though some stage 3 have them
    Oct 16 2007
    Brooklyn NY
    Re: APR BiPipe
    i might have to consider the TBB over that as well then... on another note, the Forge 007p that is provided will be a bit of a pain to get it working right... i started a thread about it a few weeks back and a few of us had problems with the DV not functioning right due to the size and vacuum hose. but it might be a small fix...
    anyways, if you have 500-600bucks.. go for it.. to each their own...
