I have been using AZ for months to educate myself, but I have no real mechanical education, so please forgive me if I sound like an idiot. I've had my 03 A4TQM for about six months and I decided to save money and work on it myself.
I had a CEL, VAG-COM gave me the following codes:
2 Faults Found:
17519 - Oxygen (Lambda) Sensor Regulation: Bank 1: System too Lean
P1111 - 002 - Lower Limit Exceeded - Intermittent
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 001 - Upper Limit Exceeded
Readiness: 0000 0001
Also under Instruments I get:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
After hours of serching AZ and other forums I decided to run these LOGS:
http://spreadsheets.google.com/pub?k...8WRipE0VrtLNTg
After I ran the logs I spent several more hours searching the forums, and have come to the conclusion that I either have a boost leak (most likely), a bad coolant temperature sensor (also likely but probably not related to the engine fault codes), or a bad O2 sensor (not likely, but it was in a thread somewhere).
So my question is, am I close? Or am I way off? If I have a boost leak wouldn't it be more evident on the channel 115 log? And why can't I find the boost leak? When I try to wrap my head around it, I figure that if I have a boost leak somewhere, more air would be getting in than what the ECU is reading, causing more air than fuel, which equals lean. Am I even on the right track? As I said before, I am new at this, and what little I do know comes from forums, so please feel free to talk down to me. Thanks in advance.
