Results 1 to 14 of 14
    Jan 21 2006
    97 A41.8QM
    Iowa City, IA
    Cheap OEM turbo timer
    Looking for a way to install a cheap turbo timer that looks 100% factory? For a long time I was thinking about the same thing and got sick of waiting in my car while it cooled down. Well first it has to be OEM. Next it has to have a timer. What could I use? How about a defrost switch? That's exactly what I used. I couldn't imagine a cheaper install that looks so factory.
    My car is a 97 and it came with 3 switch blanks on the dash. Install took about 2 hours. This all depends on how picky you are with your wiring and what features you want the timer to have. I made sure i could still set my alarm and also wired in the parking brake as an additional security feature.
    This shouldn't be too hard to figure out but if people want, I can post up my diagram. basically just follow the TT installs from AW but use the defrost switch as the timer. This may also work on later a4s. I guess i'm not sure if there are blanks in those that would accept that style switch or not.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: Cheap OEM turbo timer
    this would also turn on the defrost while turbo timing?
    Why not mount a turbo timer in the glove compartment? I did that and have been very happy with it. I don't have to hit the button everytime I turn off the key and I can adjust the length of time it runs for.
    Jan 21 2006
    97 A41.8QM
    Iowa City, IA
    No it wouldn't run the defrost. You'd buy an additional switch to mount and wire in. The picture on the switch wouldn't make much sense i know and there are definitely disadvantages to this (lack of adjustment etc,) just an idea if people are looking for different, cheap options.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Isn't the timer in the switch @ 10mins or something like that? It takes awhile for my rear window to defrost, and it turns itself off after a set period of time no matter what.
    Jan 21 2006
    97 A41.8QM
    Iowa City, IA
    yes it's ten minutes or so. Again, not the best option out there, just a different one.
    Veteran Member Four Rings lrg8683's Avatar
    Nov 01 2005
    S4
    VA
    lol, so your car stays on for ten minutes?
    -Luis
    Jan 21 2006
    97 A41.8QM
    Iowa City, IA
    no I push the button a few minutes before i get where I'm going.
    Veteran Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    Cumming, GA
    Id like to see how this works im curious.
    Now 2001 B5 S4
    Former B5 A4, 034 Stage 3 BT, Unitronics,H&R,etc,etc
    Established Member Two Rings DuviVr6's Avatar
    Jun 03 2008
    99.5 Avant 1.8TQM
    OKC, Oklahoma
    any pics of the install
    Jan 21 2006
    97 A41.8QM
    Iowa City, IA
    well not of the work done. but as far as the final product, imagine one less switch blank and one more defrost switch.
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    haha i think you're making it harder than it has to be
    Jan 21 2006
    97 A41.8QM
    Iowa City, IA
    http://s235.photobucket.com/albums/e...=104392600.gif
    look. I didn't start this thread for criticism. If you're not interested, then just read it and go on. I don't get why every time someone does something different on this site people hate on it. A few years ago I was talking about my meth injection and people pretty much thought of it as a joke. We see how that turned out.
    Veteran Member Three Rings nrowensby's Avatar
    May 04 2008
    1999 Porsche Boxster
    Columbia, SC
    So, how's the ground on the ebrake work? Does it only work when the ebrake is up? How do you turn it on a few minutes before getting where you are going without pulling the ebrake while driving?
    ▄▀▄▀▄▀▄▀▄▀▄▀ B8.5 Squad ▄▀▄▀▄▀▄▀▄▀▄▀
    2014 Audi A4 - Stg2 - Monsoon Gray Metallic
    2015 Audi A4 - S-Line - Ibis White
    Jan 21 2006
    97 A41.8QM
    Iowa City, IA
    good question. I wired in a relay for that particular purpose. With actual key on the relay grounds the wire. this makes the install more than it needs to be. simply grounding the wire would work well. the alarm can still function and timer will go off so the ebrake isnt much more than a safety measure.
