Results 1 to 9 of 9
    Jun 11 2008
    2008 M3 DCT Gintani SC
    los angeles
    stasis ...how much should i drop????
    stasis sl just arrived ...hre comps 19x9.5 on way...any advice on how much i should lower car?
    Oct 11 2007
    Suburbia
    Re: stasis ...how much should i drop????
    you may rub with the 9.5" rims, I'd lower it slowly over time to make sure you can clear.... Nice choice in rims though, wish I had the loot to drop on HRE's.
    Sep 23 2006
    Houston TX
    RS4, OP should be fine
    Registered Member Three Rings
    Jul 22 2008
    2006 S4 25th Anniv. Ed.
    Fed Way, WA
    Lower it slowly until she won't go anymore
    http://i234.photobucket.com/albums/e...ProfileDay.jpg
    "I think I'm going to get metal legs."
    Jun 11 2008
    los angeles
    whats "OP should be fine" ?
    Sep 23 2006
    Houston TX
    sorry I meant original poster (OP) will be fine with 9.5 width wheels and shouldn't rub. I think WinterRunner missed that you had an RS4 rather than an S4. Anyway, most people looking to keep a respectable height (not scraping on everything) and improving performance aim for 25" ground to fender height. I personally like 24.75" but everyone obviously has different opinions on that.
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    your offset is going ot be more important than the wheel width
    Jul 21 2004
    South Florida
    Quote Originally Posted by ngng View Post
    It should state in their literature what they are designed for and most people pick the bottom of those limits. Definitely do not just go by "what looks good" without consulting their optimum range specifications. As a general rule they state...
    Conservative Street Setup
    Between 1/16 and 1/32 TOE IN front and 1/32 TOE IN rear
    Ride height at 25.875” front and 26.000” rear
    (–1.0 camber front)
    Aggressive Street Setup
    Between 1/32 and 0 TOE IN on all four corners
    Ride height at 25.500” front and 25.625” rear
    (–1.5 to –1.75 camber front)
    Track Setup
    Between 0 and 1/16 TOE OUT on all four corners
    Ride height at 25.000” front and 25.250” rear
    (–2.0 to –3.0 camber front)
    WARNING! The Track Setup alignment recommendations are not for the street and will result in serious straight line instability. STaSIS accepts no responsibility with its alignment suggestions.
    But they may have SL specific instuctions that are even more specific.
    cheers! Mike
    2018 Audi S5
    Gone-
    Oct 11 2007
    Suburbia
    My bad, I thought you had just an S4....... You should most deinitly be fine with 9.5".
