Results 1 to 4 of 4
    Veteran Member Four Rings m5racer's Avatar
    Nov 20 2006
    replaceing wheel barring + rear lower control arm torqueing bolts?
    2000 S4
    Alright so im replaceing a wheel barring and my rear lower control arm. The problem is that I have a bently but it doesent tell me how much i have to torque the bolts. Can some one tell me what wheel barrings need to be torqued to? as well as the rear lower control arm assembly?
    thanks a lot
    Anthony
    01.5 A4 1.8t sport
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Re: replaceing wheel barring + rear lower control arm torqueing bolts?
    I'm 100% sure you need to use a press to get the wheel bearings in. I had to pay two different shops to get mine done right. Good luck if you're doing it yourself, lol.
    Nov 20 2006
    Thanks, but i already knew that and have a place that is going to be doing that for me.
    Is this correct? 85ft-lbs +180deg for the rear, 105(?)ft-lbs +180deg for the front)
    01.5 A4 1.8t sport
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    Good luck putting those lower control arms in what a bitch they were. Beware that some the bolts are a pain to get out, slightly dropping the subframe helps but even with that it was still kind of hard to get them out.
    2010 Brilliant Black/Magma Red S4
