Results 1 to 40 of 44
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    Can someone in pittsburgh help me...
    I am needing some help here... I can't figure this thing out- no bottom end...
    anyway, if someone knows what could be the problem... someone said the timing could be off, but the bently just says to mark the pullies.. I want to sell it...
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Re: Can someone in pittsburgh help me...
    huh?
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Veteran Member Four Rings AB18's Avatar
    Dec 17 2004
    US
    I live right by Pitt International, where are you located? And what do you need help with?
    Sounds like maybe a timing belt?
    2001 S4 6sp...has a few goodies...and JHM shifted
    Tons of parts for sale..
    GIAC A box ECU for sale-350shipped.
    http://www.audizine.com/forum/showthread.php?t=170072
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    i actually live in wv, but I work in robinson twp. I don't know exactly- maybe you can drive it or something and tell me what you think. It could be the timing, but again not sure??
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Here is a bunch of people from there. Link
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    I tried before, that page gets updated so many times, the post gets buried in a matter of minutes.
    Does anybody know if there are marks on the pullies themselves so if I take a look at the timing I will be able to tell if its off? ( the bentley is kinda vague)
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Yea. There is a timing mark on the Cam Sprocket; that mark MUST match with the mark on the Valve cover. The crank sprocket has a mark (either sprocket or the pulley) which MUST line up with the mark on the black plastic cover for the Crank Sprocket (gear).
    If you line that up once, spin the motor a revolution clockwise by hand using a breaker bar for example to see if both marks line up exactly the same.
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Village Idiot!!!
    (\__/)
    (")_(")
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    I didn't check it yet, but for future reference- what if it is lined up then after the rev they are off?
    Jan 21 2006
    6MT BT Avant Ti
    RI
    You really need to be specific on what is wrong with your car because you are just shooting blanks.
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    Ok well, I put a replacement engine in my car and when it was all said and done, it feels like there is no bottom end- it's got no guts. It feels super slow and I am not getting any more than 2-3psi (I think-guage is off) going up hill's is the worst, if I start out from a stop I can't get over 30mph. No ce light or codes. I thought of timing because of it not having any torque and the tb kit and wp was changed a few thousand miles ago by the po.
    And I was meaning if I go to check the timing marks and they line up, then when I hand crank it a rev and they are off what would be the problem?
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Well, it could be many things. You need to take it to AutoZone and have it checked for codes as there will be some stored.
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    Had it checked by a vag com no codes.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Disconnect the battery, then connect it back in after a minute. Turn on ignition for about a minute; then start the car. Go for a drive and post back on results.
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    Yes I did that-still has the performance of a lawn tractor....
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    ok couple of questions... if it was out of time would I still get normal boost? And if the turbo was broke, would I get a cel or a code?
    Dec 17 2004
    US
    I have a vag com...if you still can't figure this out we could prolly meet up and do some logs.
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    yea that would be great, I really want to get this figured out.
    Veteran Member Four Rings MultiAudis's Avatar
    Mar 12 2006
    01 Allroad 6mt, 01 A4
    NoVa
    sounds less like timing and more like turbo/boost issues, of which there are multiple culprits... waiting to hear the results of a vag scan. When the wastegate flap on my turbo was going, it slowly boosted less and less until the flap finally broke. During the low boost process, the car felt exactly like you are describing
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    its your turbo!!!! check your wastegate and see if the flap is open, it happened to me. If the wastegate is good then your turbo took a dump.
    open your hood, have someone press the gas pedal to build pressure, then you check the driver side intercooler to throtle body hose and see if it inflates, like its got pressure in it while is high reving.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Forum Moderator Four Rings blacka4's Avatar
    Dodge RAM 1500
    Pittsburgh Area
    Quote Originally Posted by quattroforte View Post
    Dude, you posted once and never again back in april. We didn't blow you off...we just need reminding..we like to drink. I live in the north hills and can vag your car however I am crazy busy at work and it would have to wait until monday at the earliest. let me know what you would like to do and visit us again in the pittsbugh forum. I promise we won't bite...
    But I am with the other guys here seems to be your wastegate is stuck open and the car will not prodice boost.
    -Rob - Moderator - PM Me!
    RIP:1999.5 Audi A4 1.8TQ Tip Brillant Black
    2009 Dodge RAM 1500 Crew Cab Sport - AZ Plate Frame - Bone Stock otherwise
    2014 Jeep Grand Cherokee Summit
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    well I put this turbo on a few months back thinking the one on the car was shot and it was doin the same thing. wastegate looked good, but it was used so I guess I could have had 2 bad turbos.
    Sep 14 2006
    Lansing, MI
    check if the turbo is building boost. i told you how to do it. have someone step on the gas (car in neutral) and you check if the driver side intercooler hose inflates like when a snake breathes.
    SOLD
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    ok i'll try it (tho I don't need another person I can just move the butterfly on the tb)
    Apr 01 2007
    Irvine
    my guess, in order of likelihood:
    1. turbo
    2. N75
    3. ICM
    4. timing
    the majority of other things that would cause this, I think, would throw a CEL. You're describing something very similar to what I experienced when my ICM went bad.
    Does it sound/feel like it's healthy when you drive it? My car was hesitating and bucking, not smooth at all.
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    It does feel like it's hesitating a little when driving normal, but I've been driving it like this for months and I'm not sure anymore. I checked the n75 (from the bentley) and it was within spec but different numbers(ohms iirc) than another I have, so I might swap it out and see what happens. ALSO- will the turbo have an effect on low rps's, like taking off in 1st? It feels like if I don't do it just right, it will either stall or burn up the clutch. I'm gonna have to have one of these guys around pit drive it or something to see what I mean.
    Apr 01 2007
    Irvine
    check the ICM. It's right above your airbox and it takes like 10 min to swap it out with a friend's. It would have a huge impact on taking off in first... but it's pretty noticeable and I doubt you'd drive the car for months if it was that bad.
    Nevertheless, a few minutes is worth it.
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    Well I'd have to find somebody to swap with. And pipe, I tried that and it didn't really expand..it was pretty stiff though.
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    I got time today after 3 if one of you guys could help me out.
    Sep 14 2006
    Lansing, MI
    Did you reved it high enough? dont be scared to go WOT, thats when it builds boost.
    SOLD
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    I'm pretty sure
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    ok I just went wot earlier (I guess I never really did before) but anyway it went to about5psi and then I couldn't get it to do it again till I shut the car off and took another drive. Could I have a boost leak that won't throw a code?
    Sep 14 2006
    Lansing, MI
    I am pretty sure its your wastegate!!!!
    SOLD
    Dodge RAM 1500
    Pittsburgh Area
    wastegate stuck open
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    When I put the turbo in months ago(it was used) it was tight (unless it wasn't tight enough?) and still acting the same as it is now... so ? I did swap out the n75 for another one yesterday and still same deal.
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    Could the turbo be bad if there are no signs of it being bad? I can get another cheap, but I'm wondering if I need it.
    Registered Member Two Rings
    Aug 19 2007
    central oregon
    Carnegie Mellon is my first pick for college... Trying early decision...
    Any tips?
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    Will the vagcom show if the timing is off?
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    Can the vagcom show timing being off and can I have a boost leak without a cel or code?
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    When I unplugged the n75 it acted the same.
