Results 1 to 12 of 12
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    *** AZ Intro - NEW : Density Line Subframe & Differential Mounts ***
    Month after month new products keep hitting the forums
    Mount, Density Line, Subframe Front, B5 Chassis
    We are VERY excited to be announcing the release of our 034Motorsport Track Density Subframe mouts for B5 Audis!
    WHAT THEY ARE: A new line of solid filled rubber motor mounts made FOR us by OE suppliers to OUR specifications.
    TRACKDENSITY Mounts are solid rubber mounts, but with an 85durometer approx 50% stiffer than stock, these are solid for all practical purposes and result in ZERO drivetrain movement. Vibrations from the engine are noticeably increased but not horrible. Definitely not smooth and quiet like stock mounts, but in return you get a completely locked down drivetrain with NO slop or deflection. These are perfect for the street/track enthusiast who doesn't mind a marked increase in vibration from the drivetrain.
    NOTE, THIS IS NOT AN OE MOUNT AND ARE NOT AVAILABLE FROM ANY OTHER SOURCE - These are built by an OE supplier to 034Motorsport specifications.
    Mounts will fit all B5 chassis cars. These mounts are recommended for vehicles with increased handling limits, Track Density Subframe mounts will ensure suspension geometry does not change at high suspension loads like OEM do.
    Price per set of mounts, enough for the front subframe
    RETAIL = 180US
    Mount, Diff Carrier Pair, B4/B5
    We are VERY excited to be announcing the release of our 034Motorsport Street Density and Track Density motor mounts for a wide range of Audis!
    We've been testing these mounts for some time to ensure they are reliable and meet the criterion for the intended use - results so far are very exciting!
    WHAT THEY ARE: A new line of rubber motor mounts made FOR us by OE suppliers to OUR specifications.
    STREETDENSITY Mounts are solid rubber mounts with a 50 durometer about 10% stiffer than stock, this means they still ride smooth and quiet but provide a marked improvement in drivetrain dampening over stock mounts. Livable street performance with serious sport intentions. Note, since there are no voids or air pockets in these mounts, even though the rubber is only 10% stiffer, the resulting reduction in drivetrain movement is actually 25% stiffer.
    TRACKDENSITY Mounts are also solid rubber mounts, but with an 80 durometer approx 90% stiffer than stock, these are solid for all practical purposes and result in ZERO drivetrain movement. Vibrations from the engine are noticeably increased but not horrible. Definitely not smooth and quiet like stock mounts, but in return you get a completely locked down drivetrain with NO slop or deflection. These are perfect for the street/track enthusiast who doesn't mind a marked increase in vibration from the drivetrain.
    NOTE, THIS IS NOT AN OE MOUNT, OR AN RS4 MOUNT, AND ARE NOT AVAILABLE FROM ANY OTHER SOURCE - These are built by an OE supplier to 034Motorsport specifications.
    We have tested these mounts on our own B5 1.8t quattro for over 10k road miles and 6 track days, upon recent removal they still looked like new..
    These mounts replace the upper differnatial carrier mounts, the 2 small bushings that press into the carrier that holds up the rear diff.
    Mounts will fit all B4 and B5 chassis cars including Passat, A4/S4, A6, 90 Quattro, RS2 and many other applications, feel free to contact us for clarification.
    price PER PAIR for one car.
    RETAIL = 24US
    AZ PRICE = 205US SHIPPED for the set up
    Please send me a PM when you are ready to order!
    Feb 26 2006
    Earth
    Re: *** AZ Intro - NEW : Density Line Subframe & Differential Mounts ***
    ALL PM's replied
    Feb 08 2008
    01' 2.9L GT S4 racecar built for TA/GTS competition
    North Jersey
    are the subframe bushings the same size frt/rear?
    Veteran Member Three Rings awdbiturbo's Avatar
    Apr 20 2004
    01.5 S4 /95.5 URS6/72 914/
    Boston
    Thanks Dan@034 i just ordered a pair, i can not wait to try them out. :-)
    2001 Audi S4 Stage 3+/996TT with mods/HURACAN LP610-4 VORSTEINER NOVITEC VF ENGINEERING / 22 AUDI RSQ8 NARDO CARBON/22 RS6 NARDO BLACK OPTICS IE EVENTURI CTS
    Feb 26 2006
    Earth
    I am not Dan :P
    Apr 20 2004
    Boston
    Quote Originally Posted by Issam@034 View Post
    I am not Dan :P
    i know sorry, dan is my rep i have been ordering from him for sometime now
    Mar 20 2008
    Italy
    Quote Originally Posted by Europowerhaus View Post
    ^^x2 ????
    RS4 B5
    Feb 26 2006
    Earth
    Yes they are :D
    Feb 26 2006
    Earth
    And more set ups out the door!
    Thank you AZ for the continued support!!
    Mar 20 2008
    Italy
    So it would be 360$ for a complete set up f+r??
    Tnx
    RS4 B5
    Feb 26 2006
    Earth
    Yes
    Veteran Member Three Rings K04B5's Avatar
    May 28 2007
    Northern Virginia
    alrighty I'm confused... I know there are 4 mounting points for both the front and rear subframes. I also thought that the bushings were different for the rear subframe than the front subframe... so can these "front subframe" bushing be used for the rear subframe (differential) as well? of just for the front and rear mounting points on the front subframe only? Follow?
    just realized how old this post was... sorry, found it doing a search
