Results 1 to 18 of 18
    Junior Member Two Rings Racemagicr1's Avatar
    Feb 18 2008
    Tampa
    big turbo fmic question?
    whats a good front mount that can easily be bolted up to the gtrs eliminator kit without any fitment issues and tht produces good numbers?
    2004 Audi A4 USP 1.8T
    Feb 17 2005
    Sarasota, FL
    Re: big turbo fmic question?
    Any will fit with the GTRS as it fits in the stock turbo location. I would recommend an ER Comp if you want the best results
    Buncha motorcycles
    Memphis, TN
    my racetec fit perfectly without any trimming... email [email protected]
    Er comp is the shit though.....
    APR Stage 2/AWE Intake
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    ER comp was designed perfectly for the GTRS elim kit. We just installed a black anodized ER comp on Gregs B6 and only took us about 2 hrs to get it installed, cut the rebar and get the bumper back on. Nice part is that the pipes fit perfectly to his elim, so we didn't need to make any modifications to the pipes.
    Oct 29 2005
    10speed
    San Francisco, CA
    cut the rebar?
    - Clint
    Jul 07 2004
    socal
    cut the rebar?
    Yes, the bottom section of the bumper support(rebar) needs to be notched out to allow the 3" thick ER core to sit up in that area. If the person doesn't want to cut the bumper support they can order the "Full" kit which includes a custom metal bumper support.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Yes, I prefered not to get the full kit, I modified my OEM rebar and am using a Setrab transmission cooler.
    I also prefered not to use the T-bolt clamps as they are not necessary, the I/C is such a perfect fit that standard stainless steel clamps work perfectly.
    The route I went may not be for everybody since it is so stealth, you cannot even tell that I have a FMIC, (most people that spend $$$ on a FMIC want to show it off) heck if you open my hood, you cannot even tell that my engine has been modified at all (unless you count the test pipe).
    Buncha motorcycles
    Memphis, TN
    how did u "modify" the rebar?
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by Papachristou View Post
    Measure twice, cut once. 4" angle grinder with a metal cutting wheel. Took all of about 10-15 minutes, basically I cut a C notch recess out of it for the intercooler to fit into.
    To make the lines perfectly straight, I used 1" blues painters tape to mark the line I wanted to cut.
    You do need to remove the rebar from the bumper, but this is not too difficult at all, I have done this before though with my old FMIC.
    Oct 29 2005
    10speed
    San Francisco, CA
    how much less is the kit that you got greg?
    - Clint
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I sell the basic kit for $200 less than the full kit.
    The differences are that the basic kit does not contain the ER rebar, transmission fluid cooler, hump hoses or T-bolt clamps.
    This is the power steering cooler I went with, I will be mounting it where the OEM SMIC used to be at.
    Feb 18 2008
    Tampa
    how much would install cost or is putting one on pretty straight forward that almost anyone can do it. and where would you guys recomend i order one.
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Quote Originally Posted by Racemagicr1 View Post
    You can order it from 400HPA4 and it's very simple to install. Just use a write-up and post up here if you have any questions.
    Feb 18 2008
    Tampa
    cool thnx to everyone
    Oct 29 2005
    10speed
    San Francisco, CA
    Greg dont you think regular hose clamps will blow off?
    - Clint
    Jul 07 2004
    socal
    The Sport and standard Competiton kits from ER come with normal clamps.
    If installed correctly and a good bead on the pipe(like Fred puts) then it shouldn't blow off.
    Since we installed it on his car, each of us took turns running his car at 23-25psi at the BOTI event in Sacramento and the hoses held just fine. Last weekend his wife drove the car down to socal for the Socaleuro event and then back home.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    No, not a chance in the planet they will. Regular hose clamps actually hold better than t-bolts if the piping is made correctly with proper beads.
    Regular hose clamps distribute the load around the silicone much more evenly than t-bolt clamps do.
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by 400HPA4 View Post
    is that bar and plate? i am wanting to move mine over there as well, just need to take the time
