Results 1 to 22 of 22
Thread: Just ordered
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Just ordered
    Well i just ordered
    and
    Could anyone point me to the B&M video or any other good guide for the install? And any tips on putting on the new grille?
    Aug 09 2007
    Mount Airy, MD
    Re: Just ordered
    directions for the short shifter should be on the B&M website
    as far as the grill, just pop out the old one, there are plastic taps you can see from the inside and pop the old one in. it should take you a solid 30 seconds. just a heads up on that particular grill, it doesnt seem to have any place for the hood latch, which could make things interesting. i think you might have to dremel a hole for it.
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    Re: Just ordered
    i've been thinking about ordering that cheap shifter... i should just do it
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Re: Just ordered
    ill let u know if its legit ha
    Aug 09 2007
    Mount Airy, MD
    Re: Just ordered
    ive got one, its pretty good
    - Will
    The Avants Timeline
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Re: Just ordered
    How hard was it to install?
    Veteran Member Three Rings f15046's Avatar
    Oct 30 2007
    Griffin, GA
    Re: Just ordered
    The Ebay shifter is identical to B&M
    I do work around the South East on your 1.8t or 2.7t, PM for more info
    ** 2001 A4 TQM
    -Fully built 2.0, GT3076, SPA mani, custom 6-puck clutch, Unitronics tune, Walbro 255, and much more
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Re: Just ordered
    That doesnt help me haha
    May 22 2008
    St Clair Shores, MI
    Re: Just ordered
    I had gotten what looks like the same grill you did. The hood wouldnt even close due to lack of hole for the latch and the fitment was so horrible that I didnt even bother with it. Hope yours is better lol. Being a noob is a PITA
    13 S4 Monsoon Gray - 6MT l sports diff l Nappa l Atlas l EPL Stg2
    DP l MercRacing HX l iAbed TB l Sach's Xtend l AWE Track/Touring w/ res DPs l 034 Xbrace & drivetrain mounts l P3 Track
    Aug 09 2007
    Mount Airy, MD
    Re: Just ordered
    my install was a pain in the ass. your going to need a drill to get to two of the screws in order to take out whole shifter assembly. that and pay attention to the shift linkage before you take it off. just a few things i wish i knew before i did my install.
    - Will
    The Avants Timeline
    Senior Member Three Rings Insomniac's Avatar
    Jun 03 2008
    Hershey
    Re: Just ordered
    Quote Originally Posted by SykoraA4 View Post
    I didn't need any drill? If I remember I used a socket, allen wrench, and maybe a screw driver. Oh and a magnetic thing will help when you drop the screws below the shift assembly.
    free earl
    Veteran Member Three Rings firstars's Avatar
    Jan 22 2007
    NNJ
    Re: Just ordered
    im sorry that shifter is a piece of garbage, I had it in my old b5 JHM ftw
    2007 Cayman S Racecar For Sale!
    2017 Raptor Avalance Gray Daily
    2012 Cayman S Track
    2013 S4 Sepang Blue Traded
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Re: Just ordered
    So the grille needed some modification, just needed to cut a small chunk out for the hood latch. Used a dremel and it turned out great, ill post pics as soon as i find a camera. Short shifter took some time, but definitely worth it, although i bet the JHM is nice as hell.
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    Re: Just ordered
    should of unhooked the 'button' that comes out of the grill and just reached under the hood and pulled the metal lever when you popped the hood. no reason to cut that grill. i love the none hole look.
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Feb 09 2007
    00 S4
    MA
    Re: Just ordered
    I've seen people bend the hood latch straight (downwards), im guessing when you pop it you can reach under and push it forward
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Re: Just ordered
    ha sorry for the shitty quality, only camera i got is on my RAZR.
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Re: Just ordered
    Quote Originally Posted by black99.5a4 View Post
    damn, i wish i would have known that before i cut it ha. It still looks clean tho, ill take some close ups tomorrow to prove it :) The latch button fills in the gap almost perfectly.
    Jan 26 2007
    Charleston SC
    Re: Just ordered
    Quote Originally Posted by firstarsbrnwhit View Post
    fcuk the JHM... i don't think a shifter is worth $250.
    Jan 22 2007
    NNJ
    Re: Just ordered
    more than a shifter. Its a whole kit that replaces more than just the shifter.
    2012 Cayman S Track
    Dec 19 2007
    1988 Mercedes 300E, 2008 Triumph Speed Triple
    Colonie NY
    Re: Just ordered
    How did you like your JHM? I am not worried so much about throw reduction as just better precision. I am planning on ordering in the next week or so and cant wait, it just looks so damn well built..
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Re: Just ordered
    i got the same shifter and same grille.. for the latch i just bent it down and when i pop it i can reach from under and pull it. the shifter took like 30 mins to install and much better than stock. for the money i like it a lot. never driven the jhm personally but i might be upgrading if someone buys it off my christmas list. lol
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Re: Just ordered
    Quote Originally Posted by BADB5A4 View Post
    JHM piece is the best I've shifted with and owned. I had a B&M I was always having to readjust. Neuspeeds is also nice, but not JHM nice and crisp. I would grab all their items (linkage and bushing as well). I am one of those people on here with everything upgraded and replaced and the JHM brought it even more together than ever. The linkage is probably even more noticable on it's own, but I did all 3 at once.
