Results 1 to 4 of 4
Thread: Forge dv
    Nov 26 2007
    Question Forge dv
    Thinking of changing my diverter valve on my o6 2.0t anyone have any feedback on the forge DV ? or should I just stick with the stock one?
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Re: Forge dv
    well why are you changing? did it tear? if so go get a new one under warranty if you are still in warranty. If not and you are chipped you might as well pony up and get the forge DV
    The usual things!!
    Resistor Install
    Veteran Member Three Rings Subaru71's Avatar
    Jan 15 2008
    2010 DGM Impreza WRX
    Chino Hills, CA
    Re: Forge dv
    I have a factory "C" dv laying around if you want to buy it...
    if you aren't chipped the stock should be fine.. if you're leaking then get a revision "C"
    2008 Phantom Black TQM
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Re: Forge dv
    Newest version is G fyi
    -Kris
