Results 1 to 14 of 14
    Senior Member Two Rings S4stageIII's Avatar
    Dec 07 2006
    2013 Audi S6 stage 1 & 2001 Audi S4 AWE stage 3
    G-Burg, MD
    B6 AWE GT28R kit fit on B5???
    I bought this kit from a fellow enthusiast that had a B6 A4 and I wanted to know if I would have any issues installing this in my car (99.5 A4 avant, 5 speed)? I realize that I should have asked this question before I purchased the kit, but I have no patience. Can anyone tell me where I can get a custom tune for this application or would I be able to use tune that some company has out there for a GT28R application? Sorry for the dumb questions, but I'm new to 1.8T's.
    TIA...
    Nogaro S4..
    (AWE RSK04, Milltek DP, 710N, AWE intercooler, APR bi-pipe, APR snub, ASP DTS, Stasis Street, Neuspeed exhaust, ECS pulley, ECS stage 3 BBK, E-codes, RS4 bumper, AWE vented hood, etc...)
    Dec 05 2007
    Re: B6 AWE GT28R kit fit on B5???
    Did he have a high flow exhaust manifold for it? If so, it will not bolt up to your engine. You have a transverse engine while he has a longitudinal. Other than that, everything else should be a go . As for tuning, there are many tuners that exist. CTapp and Unitronics seems to be the most liked in the B5 platform. But you have others such as APR, GIAC, Revo, etc.
    What was included in the kit the guy sold you?
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    WOW, is this a jjoke, did I read something wrong??
    Since when did the B5 EVER have a transverse.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Sep 17 2006
    07 cbr600
    hahahahahhaha
    in before the flaming...
    to you and false info.
    Dec 05 2007
    I thought that the AEB had transverse and the 01 had longitudinal. Or am I misinformed. Whoops. I knew mine is longitudinal and thought the older ones had transverse. Sorry for the wonrg info. Everything should bolt right up then.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Wow, that was a doozie Seerlah.
    hardware wise, the kit will fit.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Sep 17 2006
    07 cbr600
    Hella misinformed and spreading your misinformation
    Dec 05 2007
    ^sorry
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Only transverse mounted engine is in the TT and A3 in the USA.
    and this gizmo
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Lol
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Dec 07 2006
    G-Burg, MD
    Thanks for the help, I got the injectors, GT28R turbo, Oil feed & return lines, 3" VR6 maf, Test pipe, Turbo inlet pipe. This is the same kit that is made by AWE for the B6 A4s minus software, injector adaptors and support bracket.
    Nogaro S4..
    Dec 07 2006
    G-Burg, MD
    Thanks all for the help...
    Nogaro S4..
    Oct 30 2006
    B8 A4 Avant 6spd
    LOL.
    -18 718 GTS
    Veteran Member Four Rings gmx's Avatar
    Mar 01 2008
    '12 1M
    Sydney, AU
    edit/delete that post already.
