Results 1 to 40 of 67
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    My exhaust dump (2.0T)
    There is currently another thread, but I feel the title/subject is making it lack views. This will be an overview of my install, impressions, and a free for all for any questions of people interested. Video posted in post #22!
    For my attention getter, I give you my install completed as of today.
    Blurry, but this is how far it hangs down. Barely at all, so notice there is plenty of room to run a cut-out.
    Position. I wanted to mount it further up and only on the downpipe, but the center differential was there and I didn't feel like welding it in there. It replaced the exhaust sleeve, so my exhaust system is one solid piece right now
    This picture shows how it sits right after the differential, but over an inch away from the driveshaft for plenty of clearance.
    Mounting the switch. I was going to put it in the glove box for a clean install, but didn't feel like opening it and reaching in there all the time (since I like to play with it ). Instead, I put it in the cubby hole under the steering wheel. Hole is drilled next to where the switch is laying:
    Toggle switch is easily reached, even with the manual in there. Out of sight, and in hand in under two seconds
    Ignorance is bliss.
    Jan 24 2007
    Wisconsin
    Re: My exhaust dump (2.0T)
    Information about exhaust cutouts, or exhaust dumps.
    When I got my first 1.8 turbo, right away I started looking for exhaust solutions. I looked at tons of $800+ cat-back systems, then I came across some suggestions to buy a dump tube. I figured a dump tube would free up my exhaust and give me the least amount of back pressure possible, so I would get the best results from it.
    I then learned there are two types of dump tubes: pneumatic and electronic. Pneumatic dump tubes are activated by a vacuum line, and the butterfly valve opens whenever you get into higher boost. Electronic dump tubes have a physical switch, so you can have the dump open/closed or any position in between.
    I figured the obvious solution would be the electronic dump, but it had a higher potential to break. Since it uses an electronic motor, you can put stress on it by trying to open or close it further than it can go. I went ahead and bout the 2.5" electronic dump from Quick Time Performance for a cheap $205 plus shipping. I only had to pay maybe $35 to get the y-pipe welded in, so this setup is less than half the cost of any respectable cat-back system.
    Ignorance is bliss.
    Jan 24 2007
    Wisconsin
    What you need to know if you purchase an exhaust cutout.
    No matter which type or brand you choose, I think all of them are supposed to be "maintenance free". But this is BS. They are not lubricated or sealed very well, so before you install yours you need to saturate the shit out of it with antiseize or some similar compound. My first one completely seized after one winter in Wisconsin (daily driver) so I had to purchase another one.
    So when you get yours, the first step is to lubricate all of the moving parts. I chose to use antiseize (found at any parts store), which I think is the best way to go. Here is what mine looked like after I worked the paste into/around where the shaft twists around:
    It is important to lube it right away, and probably clean the housing every once in a while. I didn't touch my first one ever, and this is what it looked like after almost one year...
    Tons of carbon deposits, and completely seized up and not moving. So don't be like me and have to waste $110 on another cutout body!
    Ignorance is bliss.
    Jan 01 2008
    Long Island NY
    Nice. Im getting mine done Friday along with installing my downpipe. I will do three dyno runs.
    1) Pump Gas with Full Exhaust
    2) Pump Gas with Dump valve open
    3) Repeat 1st
    Jan 24 2007
    Wisconsin
    Awesome , that will be wonderful to have those numbers.
    Upon opening mine, I notice much better throttle response, and turbo lag in higher gears seems to be better. I have no numbers to prove anything, but those are my impressions.
    Also, holy shit is this loud when paired with a test pipe! It is MUCH louder than when I had it on my 1.8T with oem cats. and instead of "farting" when you let off the gas (as you test pipe people all know), it goes "AHHHHHHHHH!!!!!!!!"
    Ignorance is bliss.
    Jan 01 2008
    Long Island NY
    does the exhaust pop.
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Kitchener, Ontario
    looks good. thanks for posting this. this was exactly what i was looking for my exhaust!
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Veteran Member Three Rings AlexK's Avatar
    Sep 11 2007
    San Mateo, CA
    Put up a youtube clip, I wanna hear this thing!
    Jan 01 2008
    Long Island NY
    even a cell phone video
    Jan 24 2007
    Wisconsin
    Quote Originally Posted by Auditude2.0T View Post
    When I had it on my 1.8T (stock exhaust) it would backfire in 1st/2nd gear if I revved it past 6,000rpm.
    I drove around with it open for an hour tonight, and did not get a backfire. It is fucking loud, it is really gurgly and makes lots of little popping noises, and when I let off the throttle (with a test pipe) it makes a big POOP noise instead of the old fart sound.
    I can do a cell phone vid, but I have an old camcorder that works better... but that's really hard to edit and get online. Tomorrow after work I can get something up, and hopefully it isn't too shitty.
    Ignorance is bliss.
    Jan 24 2007
    Wisconsin
    I was just thinking that my Digital Rebel can not take video, but my girlfriend has a Canon Powershot that takes decent video... I will use that tomorrow and get something cool for you guys
    Story time:
    I was driving down our Main Street with my exhaust at like 150dB, and watching for cops all paranoid while I was having my fun. I car familiar headlights, but it was unmarked and had a normal plate and didn't look like a cop. I said whatever and kept going, then it turned it's lights on and pulled over some old Bronco in the next lane and two cars behind me suckaaaaaaaaaaaaaaaa, nobody suspects the Audi
    Ignorance is bliss.
    Jan 01 2008
    Long Island NY
    lol thanks phrost. i cant sleep till i hear this vid. call your girlfriend and get her phone now
    Jan 24 2007
    Wisconsin
    She is sleeping in my bed right now, and her camera is somewhere in my bedroom.
    But it's late, and I have to be at work at 5am in 5 hours, so no can do tonight
    Ignorance is bliss.
    Jan 01 2008
    Long Island NY
    Quote Originally Posted by Phrost View Post
    is that her in your sig?? if so your one lucky guy.
    Jan 24 2007
    Wisconsin
    No I don't date 15 year olds
    But last weekend, my friend's little sister who is 17... ...ah nevermind
    Ignorance is bliss.
    Jan 01 2008
    Long Island NY
    im 17.
    Jan 24 2007
    Wisconsin
    But I'm turning 42 in 1 month
    Ignorance is bliss.
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    vid plz
    Apr 18 2008
    Jacksonville, FL
    Phrost, because it's not in the new user faq and i'm too lazy to find a tape measure, what size kit did you buy from QTP?
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Jan 24 2007
    Wisconsin
    Our exhaust where I mounted mine (the downpipe) is 2.25". Actually... My y-pipe is 2.5" since my TT exhaust was 2.5", but the shop said it would fit right over the 2 1/4" stock piping like a sleeve (which it did) so that is why it looks a tad bigger.
    Hell, I already had it and wanted a free dump
    I took some quick vids, I'll try to get them up right now.
    Ignorance is bliss.
    Established Member Two Rings korbis's Avatar
    Jun 19 2008
    2007 A4 FWD 6MT
    Santa Clarita
    Phrost I went to my local muffler shop and got the Y-pipe installed. I haven't ordered the exhaust dump yet, but is sounds so SICK!...imo.
    I currently have a custom magnaflow exhaust setup and the exhaust note disappears after 4k rpm's. After installing the Y-pipe, it growls and low rpm's and screams through out the rest of the power band.
    One question though, is it ok for it to always be open?
    spanks
    Jan 24 2007
    Wisconsin
    Here is a quick video
    http://www.youtube.com/watch?v=hb480ep3SxE Note: right under the video, you can choose to "watch video in high quality"
    Sorry it is kind of crappy... My gf's Powershot has a shitty microphone, I had to hold it so the microphone would be be covered up, and I wasn't used to a piece of shit girly little wrist strap fluttering around so that is a little annoying. It'll do for now though
    Ignorance is bliss.
    Veteran Member Four Rings Vorsprung's Avatar
    Feb 26 2008
    Raptor, FD RX7
    Long_Island/NY
    oooo sounds boomy or something i dont know how to explain it and LOUD. hehe
    -Ian
    Jan 24 2007
    Wisconsin
    My video makes it sound quieter than it really is. It doesn't capture anything but WOT really, so take this as a sample of what it is kind of like
    At 1:01, I actually got a very loud backfire (which is why I jerked the camera because I was scurrrred) but the camera barely even captured it. Only backfire I got so far, but it is really poppy/gurgly when you let off the throttle.
    Ignorance is bliss.
    Jan 24 2007
    Wisconsin
    That's cute, you guys are all fighting and shiznit
    Sounds better than my video
    Ignorance is bliss.
    Jun 19 2008
    2007 A4 FWD 6MT
    Santa Clarita
    Thanks my good sir
    Jan 01 2008
    Long Island NY
    that sounds nasty im getting mine done either friday, Saturday or Monday.
    Jan 24 2007
    Wisconsin
    korbis doesn't seem to really get on it or drive at WOT in any of his vids. Honestly. with my 1.8T (and no test pipe) it was just loud... but with my 2.0T (and ECode test pipe) it is muthafuckin loud! Very very holy shit. I'll try to find someone with a good camera in the near future to capture the true sound of what you get.
    Ignorance is bliss.
    Jan 01 2008
    Long Island NY
    its freaking straight turbo no exhaust.
    Jan 24 2007
    Wisconsin
    Yes, but I don't want curious people to watch the videos and think it's not that loud. It fucking hurts my ears if I drive past cars/walls (or through that tunnel ) so it is serious business.
    Idle is actually very quiet, driving normally pretty much sounds like your exhaust fell off, but getting on it sounds like a V8 with straight pipes. Not for the faint of heart
    Ignorance is bliss.
    Jan 01 2008
    Long Island NY
    IT SOUNDS LIKE A V8!!!!???!!!???!!! OMG MY DREAM. lol
    Jan 24 2007
    Wisconsin
    You know what I mean, foo. People think AWE + test pipe is loud, but they don't understand
    Ignorance is bliss.
    Jan 01 2008
    Long Island NY
    lol this thing is going to be dragster loud when your on it. I can't wait to set off car alarms like crazy.
    Jan 24 2007
    Wisconsin
    Everyone stares at me, ricers think I'm in some sort of a drag car because it's loud as fuck and faster than them, and normal people floor it at me just being stupid then have to freak out and plug their ears as I floor it in return and pass them when their windows are down.
    Shit is fun
    Ignorance is bliss.
    Jan 01 2008
    Long Island NY
    u sound like a fat kid at a buffet.
    Jan 24 2007
    Wisconsin
    oh god I could use a buffet right now. fucking OM NOM NOM NOM
    Ignorance is bliss.
    Veteran Member Three Rings snosk8tr123's Avatar
    Jan 08 2007
    2007 Audi A4 2.0t
    Orange County
    I understand that its loud, but is it honestly TOO loud? I'm 17 years old and I like loud exhausts, but I don't like it when it's super annoying and drones and hurts my ears. Is it a nice sound??? Also how well does the valve open and close? Can i close and open it as much as i want? Does it open half way to get half the sound, or is it all or nothing?
    P.S. I have eurocode testpipe also
    s-line titanium + plate filler + ecs smoked sidemarkers + GIAC 91 octane + Koni Coilovers + e-code test pipe + DMH electronic exhaust cutout + forge dv + bov spacer + tint + LED city light + LED license plate bulb + Yellow PIAA fogs + White Nokya Headlights + European rewiring of lights + Clear corner and blacked out housing + Red LED door lights and foot well lights + debadged + Black audi rings + Light smoke taillights + VMR vent boost gauge + DOPE sticker (+50 whp)
    Apr 18 2008
    Jacksonville, FL
    do-want.
    but i gots nothin else goin on in the go department, so it's essentially ricing. bummer.
    SOLD 10/2011
    Veteran Member Four Rings Vito Roma's Avatar
    Oct 08 2007
    Syracuse, NY
    nice post
    '12 Bril. Black A4 2.0T/Quattro/Prem+/Sports package
    SLine body/Sline Door sills/3 spoke pref wheel w.Paddles/Sport seats/VMR 708 Matte Black(19x8.5) **For Sale**/Custom Black OEM caps/35% Tint/Needle Swipe/Fob/"Wink" & Amber Delete/More VagCom/RS4 Grille/ Hoen Endurance Fogs/ST Coilovers *Sold* /Debadged/V1 w. Concealed display *Sold*
