Originally Posted by
blmlozz
no, but it is a bit ghetto rigged, I couldn't find a 2.75" inlet filter and so I'm using a 3" off the shelf k&n with some foam weather striping material as a filler. I'll check it.
What tune are you using and is that the stock maf housing your using?
Cant find a 2.75" inlet cone filter?
Take your pick
RU-5090 2.75 in (70 mm) 3.75 in (95 mm) 4 in (102 mm) 5.563 in (141 mm) Rubber 0.813 in (21 mm) 0 degrees 0 in (0 mm)
RU-3120 2.75 in (70 mm) 4 in (102 mm) 2 in (51 mm) 6 in (152 mm) Rubber 1 in (25 mm) 10 degrees 0 in (0 mm)
RU-3590 2.75 in (70 mm) 4 in (102 mm) 2 in (51 mm) 7 in (178 mm) Rubber 1 in (25 mm) 10 degrees 0 in (0 mm)
SN-2590 2.75 in (70 mm) 4 in (102 mm) 3 in (76 mm) 5 in (127 mm) Rubber 1 in (25 mm) 10 degrees 0 in (0 mm)
SN-2600 2.75 in (70 mm) 4 in (102 mm) 3 in (76 mm) 6 in (152 mm) Rubber 1 in (25 mm) 10 degrees 0 in (0 mm)
SN-2620 2.75 in (70 mm) 4 in (102 mm) 3 in (76 mm) 6 in (152 mm) Rubber 2 in (51 mm) 20 degrees 0 in (0 mm)
SN-2580 2.75 in (70 mm) 4.5 in (114 mm) 3 in (76 mm) 4 in (102 mm) Rubber 0.625 in (16 mm) 0 degrees 0 in (0 mm)
RC-9350 2.75 in (70 mm) 4.688 in (119 mm) 3.5 in (89 mm) 4.875 in (124 mm) Metal 0.813 in (21 mm) 0 degrees 0 in (0 mm)
RC-9310 2.75 in (70 mm) 4.75 in (121 mm) 3.5 in (89 mm) 5.875 in (149 mm) Metal 0.813 in (21 mm) 0 degrees 0 in (0 mm)
RC-5144 2.75 in (70 mm) 4.75 in (121 mm) 4 in (102 mm) 7.875 in (200 mm) Metal 0.813 in (21 mm) 0 degrees 0 in (0 mm)
RC-4490 2.75 in (70 mm) 5.188 in (132 mm) 3.5 in (89 mm) 4.313 in (110 mm) Metal 0.75 in (19 mm) 0 degrees 0.5 in (13 mm)
RC-4500 2.75 in (70 mm) 5.188 in (132 mm) 3.5 in (89 mm) 5.125 in (130 mm) Metal 0.75 in (19 mm) 0 degrees 0.688 in (17 mm)
RC-8410 2.75 in (70 mm) 5.25 in (133 mm) 3.5 in (89 mm) 4.344 in (110 mm) Metal 0.75 in (19 mm) 0 degrees 0.469 in (12 mm)
RC-4790 2.75 in (70 mm) 5.5 in (140 mm) 4.5 in (114 mm) 7 in (178 mm) Metal 2.5 in (64 mm) 30 degrees 0 in (0 mm)
RC-9940 2.75 in (70 mm) 5.781 in (147 mm) 3.5 in (89 mm) 4.531 in (115 mm) Metal 0.75 in (19 mm) 0 degrees 0 in (0 mm)
RU-3390 2.75 in (70 mm) 5.875 in (149 mm) 4.75 in (121 mm) 2.625 in (67 mm) Rubber 0.75 in (19 mm) 0 degrees 0 in (0 mm)
RU-4450 2.75 in (70 mm) 5.875 in (149 mm) 4.75 in (121 mm) 5 in (127 mm) Rubber 0.75 in (19 mm) 0 degrees 0 in (0 mm)
RU-3610 2.75 in (70 mm) 5.875 in (149 mm) 4.75 in (121 mm) 7 in (178 mm) Rubber 0.75 in (19 mm) 0 degrees 0 in (0 mm)
RU-4960 2.75 in (70 mm) 6 in (152 mm) 5 in (127 mm) 5.5 in (140 mm) Rubber 2 in (51 mm) 0 degrees 0 in (0 mm)
RX-4960 2.75 in (70 mm) 6 in (152 mm) 5 in (127 mm) 5.5 in (140 mm) X-Stream 2 in (51 mm) 0 degrees 0 in (0 mm)
RX-4870 2.75 in (70 mm) 6 in (152 mm) 5 in (127 mm) 6.5 in (165 mm) X-Stream 2 in (51 mm) 0 degrees 0 in (0 mm)
RU-4870 2.75 in (70 mm) 6 in (152 mm) 5 in (127 mm) 6.5 in (165 mm) Rubber 2 in (51 mm) 0 degrees 0 in (0 mm)
RC-4850 2.75 in (70 mm) 6.75 in (171 mm) 5.875 in (149 mm) 3.25 in (83 mm) Metal 0.75 in (19 mm) 0 degrees 0 in (0 mm)
E-2232 2.75 in (70 mm) 6.75 in (171 mm) 5.875 in (149 mm) 3.25 in (83 mm) Metal 0.75 in (19 mm) 0 degrees 0 in (0 mm)
Any of those are just a click order away from either K&N directly or from AJusa.com
