Results 1 to 3 of 3
    Veteran Member Three Rings Tomek6's Avatar
    Dec 29 2006
    2005 A4 USP 6spd
    Oil in piping Help?
    Hey guys. I replaced all my piping today for a Forge TIP and the rest all Samco. When I took off the hose that goes from the turbo to the metal pipe in the front. There was some oil in the pipe and hose. When I took off the small L shaped hose that goes from the metal pipe to the intercooler. A bit of oil dripped out. I got a pic of the inside of my intercooler. Anything I should do/ get checked out or is this normal?
    2005 Audi A4 USP 6spd |Revo Chip|TT 225 Injectors|Evo MS Intake w/ modified stock ram air|Samco Hoses|Forge TIP|Forge DV|VMR TP|Custom SS 2.5" Magnaflow Exhaust|ECS Snub Mount|KW V2 Coilovers|Hotchkis S4 Sways|BBS CH's|3.0 C/D, Slotted Rotors|USP Front, Rear Spoiler and Interior Trim|Cupra R Lip|B7 Rear Valance|DTH Sideskirts|Grilles|E-Codes|S4 Mirrors and Door Blades|S/w Boost Guage w/ Podi Steering Column Pod|
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: Oil in piping Help?
    that is blow-by oil, it is designed to go back through the tip/turbo/ic piping from the motor head to reduce emmisions instead of using a catch can type unit. I would not worry unless it is very excessive.
    Dec 29 2006
    2005 A4 USP 6spd
    Ok thanks. I think its been there since last year because I noticed some when I was changing the DV but didn't really think anything of it. So i guess if its been there for that long and nothing has broken it should be ok.
    Thanks for the quick reply
