Results 1 to 4 of 4
    Aug 03 2007
    2000 S4
    IDLE Misfire Help
    Hey Guys,
    So I'm getting a bad misfire while the car is idle. It runs fine otherwise. Here are the DTCs that came up:
    16534 - Oxygen (Lambda) Sensor B2 S1: Malfunction in Circuit
    P0150 - 35-10 - - - Intermittent
    17539 - Oxygen (Lambda) Sensor: B2 S1: Internal Resistance too High
    P1131 - 35-00 - -
    17538 - Fuel Trim: Bank 2 (Mult): System too Lean
    P1130 - 35-00 - -
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-00 - -
    16690 - Cylinder 6 Misfire Detected
    P0306 - 35-00 - -
    16689 - Cylinder 5 Misfire Detected
    P0305 - 35-00 - -
    16688 - Cylinder 4 Misfire Detected
    P0304 - 35-00 - -
    So far I've tried to change the spark plugs, swap ICMs and move coil packs around. Doesn't seem to be any of those. I'm kinda stumped at the moment. Any idea's or input?
    Thanks in advance.
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    Re: IDLE Misfire Help
    o2 sensor, bank 2 (driver), s1(pre-cat), swap it out and see if that helps
    B5 S4 AWE Stage 3 - sold
    Aug 03 2007
    2000 S4
    Quote Originally Posted by Rajan147 View Post
    Would an o2 cause a whole bank to misfire?
    Apr 13 2008
    Tennessee
    Quote Originally Posted by Jaded S4 View Post
    yup, especially when the O2 sensor that your car is telling you is bad is also the one that controls that particular bank...
