First I need to credit this concept from the forum post:
http://www.audizine.com/forum/showth...hlight=mbc+n75
I saw the MBC offered from JHM to adjust boost from inside the car and placed my order. I have a completely stock 2001.5 S4 with a GIAC X ECM. You may say its crazy to install an MBC with K03s because of the following reasons:
- Need a TCD (Throttle cut defender) so the rapid boost build will cause the ECM to cut the throttle
- You will quickly kill K03s
- You need a certain tune to work well with MBC
- etc..
Well I agree. I don't want to kill my sweet little snails. I found the post above and thought this was a great way to actually protect my turbos (plumbing N75 and MBC in parallel), Switching to stock for emissions testing, and going all out with MBC stand alone when I go Stage 3 or go to the track with my Giac X tune (hopefully it wont cut my throttle). The one difference (and purpose of this post) is to replace the manual valves with solenoids to switch back and forth inside the cab.
The pictures below show my pair of solenoids mounted to my sweet custom bracket (thanks lowes). The solenoids are Normally open so there is no way to screw up my turbos if a solenoid fails. I then will wire these to a on/off/on rocker switch in the cab (to accessory power). I plan to do the install this weekend so will let you know how it goes. The hardest part was sourcing the solenoids for cheap. Here is a total of the project:
- (2) STC Air Solenoids (PN 2V035-1/8) - $25
- (1) single pole double throw on/off/on rocker switch - $3
- Brass air fittings (2 plugs, 2 1/8" NPT barbs, and 2 10-32 UNF barbs - $10
- metal angle steel - $4
- Hardware to mount bracket - $3
- JHM in cab MBC - $165
Total = $210
All in all not too bad. The worst part is that you have to order packages of 10 for some of the brass fittings from McMasterCarr. I just couldn't quickly find any cheaper. My only concern is drilling in to the battery when I mount it and adding too much volume to the boost lines causing a delay in Waste gate response. Let me know if you have any questions or ideas.
Solenoids and bracket:
Bottom:
Stolen concept:
