Results 1 to 27 of 27
    Senior Member Three Rings 04_A4_1.8T's Avatar
    Apr 13 2008
    04 Audi A4 1.8T
    Utah
    What To Do Next???
    Okay so i have had my car 7 months now... it is a USP with unpainted lowers light silver on top... so far i have done a GIAC chip with big injectors... i just don't know what to do next i have been thinking of 3 things but i just wanted other peoples input... Intake and diverter valve at the same time... or full exhaust from the turbo back... if i did the exhaust i was gonna do either a test pipe or high flo cat but wouldn't that throw a check engine light? thanks for any input..
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Re: What To Do Next???
    intercooler.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Apr 13 2008
    04 Audi A4 1.8T
    Utah
    i obviously have the stock intercooler... but i am running enough boost to need a FMIC? i am not sure the amount exactly that i am running but i know it is around 20?? i think???
    Veteran Member Three Rings Carlitos's Avatar
    Sep 17 2006
    B6 A4 1.8T
    San Juan, PR
    Quote Originally Posted by 04_A4_1.8T View Post
    I'm sorry. But as far as I know USPs dont come with unpainted lowers... so you can paint them
    FlexTuning
    Amulet 1.8TM
    BAT#46
    Apr 13 2008
    04 Audi A4 1.8T
    Utah
    Quote Originally Posted by Carlitos View Post
    maybe i don't have a usp honestly have no idea which version it is lol.. it is a 6 speed manual though and the bottom bumpers are gray/matte blackish... sorry for being a total noob
    Sep 17 2006
    B6 A4 1.8T
    San Juan, PR
    haha don't worry, btw welcome to AZ
    If I were you I would do a custom exhaust with a test pipe and Magnas 14851 (just like my exhaust) .... the test pipe really makes a huge difference, and it's only around 100-160.
    FlexTuning
    Amulet 1.8TM
    BAT#46
    Registered Member Two Rings ben light's Avatar
    May 26 2008
    2003 Audi A4, 2007 Mini Cooper
    Dover pa
    I had my lowers painted. you should do a DV. I had mine done the My friend had the same thing done and did not replace the DV and it went out. You could do an intake, although the stock one is good enough. I installed a Carbonio because I like popping the hood. I also have a full Magnaflow exhaust which I had less then a month after purchasing the car 3 years ago. I am also still running the stock intercooler. I like the way the front end looks the way it is. I don't really want to cut the bumper. I hope this helps.
    _____________________________________________
    2003 Audi A4
    Giac Flash, FX Fuel Injectors, Forge DV, Magnaflow Exhaust, Carbonio intake, Eibach lowering springs, Color matched Mille Miglia 18" wheels, Vizage front lip, Erebuni wing and grill, Full Sherwood dash kit, AWE pedals, a little bump in the trunk.
    www.cepavw.org
    we roll deeper
    Apr 13 2008
    04 Audi A4 1.8T
    Utah
    i was thinking about doing a full techtonics exhaust with a test pipe but i am worried that it would make a check engine light? does it not do that? or is there a way to get around it making one?
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    You might want to change your stock DV with an oem (710N) for $45 or a aftermarket one for about $140. And I would look for an intercooler. It will help drop intake air temperature and the heat soak, either a front mounted one or a 30% bigger Apikol smic.
    and welcome!
    Beta Alpha Tau member #56
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Apr 13 2008
    04 Audi A4 1.8T
    Utah
    Quote Originally Posted by FourRings80 View Post
    and welcome!
    Who makes a good aftermarket one? i have been looking at AWE ones are they any good?
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Do you plan on staying stage 1+ or going k04, BT, BAT...
    Your decision should be based on how far you want to go with the modding. AWE, ER, racetec are quality products. A DSMIC is also an option if you like the stealth look. Just stay away from the ebay stuff. Search the forum, there's a lot of information on here.
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Apr 13 2008
    04 Audi A4 1.8T
    Utah
    i at least plan on doing a ko4... but from what i hear once i do that i will eventually wanna go BT... i know that eventually i will wanna do a FMIC cause i love how they look but i think that is a little premature at this point maybe??
    right now i have been looking at some stuff on AWE trying to see if i can tune down my car to try and save gas and then tune it back up when i feel like driving like an idiot?? any way to do that??
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Here:
    you can buy used dv like forge 007 or new 710N + custom exhaust (prolly 1/2 of the price of the brand name exhaust) + save a bit for the fmic.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Apr 13 2008
    04 Audi A4 1.8T
    Utah
    Quote Originally Posted by aaaudiprotein View Post
    Here:
    ya i think i will look for a used one... what is the life expectancy on them though?? and where is a good place to get one?
    Veteran Member Three Rings aalipio's Avatar
    Sep 03 2008
    05 S4 V8 02 A4 1.8T
    N las vegas
    How do you like the giac chip w/ big injectors?! im planning to do this soon.
    also were you bone stock prior to this mod?
    if so how much of a difference did it make compared to stock?
    thanks,
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    DV are cheap.
    testpipe+exhaust.
    then fmic
    CT4952
    Veteran Member Four Rings italian a4 1032's Avatar
    Oct 17 2007
    mass
    custom exhuast with magnaflows and a dv?
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    Quote Originally Posted by aalipio View Post
    thanks,
    The difference in night and day. From a 16.8ish 1/4 mile to about a 14.8ish 1/4 mile. DONT QUOTE ME ON THIS! I dont have the injectors yet, but I just have the regular GIAC tune and I'm running right at a 15.2 1/4 mile with my FWD. All you have to do is buy 380CC injectors and find a shop around you that does GIAC and there ya go!
    02 A4 3.0Q6MT
    -chad
    Apr 13 2008
    04 Audi A4 1.8T
    Utah
    i love the chip... and i am running 440cc injectors... but now i have an intake dv and full exhaust... so i am a little faster then i was with the chip... but even running just the chip was night and day... more pick up more throttle response louder turbo spool... well worth the money in my opinion...
    My Cars...
    1998 Honda Civic Ex... *sold*
    2004 Audi A4 1.8T Giac Stage 1+ *current*
    *Honda Cbr 600rr* Springtime
    Dec 06 2007
    440cc injectors? how? we run 386cc for this. First get the right injectors, 2nd read the noob guide and start planning suspension, sway bar, intercooler, exhaust, test pipe, turbo inlet pipe, throttle body hose, DV, and then go BT.
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Three Rings A4Triple Blk's Avatar
    Jun 10 2008
    Past - 2004 A4 1.8T Quattro 6 Spd
    LI
    This kid is off sprinting before he even knows what a jog is ... and i'm only at crawling lol i agree with AudiA4Turbo22 ... take a day off get a big cup of Joe and read every noob write up and plan out what you wanna do cuz it sounds like you're all over the place.
    B8 2011 A4 Premium+ 6 speed
    Used to B6 it
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    you can probably wait until spring for an intercooler upgrade, it's cold in Utah. go with an upgraded DV and a Magnaflow Exhaust system for under $600. I have a Hyperboost DV for sale if you want (cheap & excellent condition), just send me a message if you're interested.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Registered Member Three Rings VagStaR's Avatar
    Oct 03 2008
    04 A4 tqm. 99 saab 93 2.0T 5sp
    York, PA
    Where can the cheapest magnaflows be found, cuz I'm REVO stg. 1 right now, and getting ready to move on from that. I need exhaust!
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    Quote Originally Posted by VagStaR View Post
    it might be too late, but www.performancepeddler.com carry magnaflow system for $589.
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    DV will hold your boost better and an FMIC just makes a great power difference, and makes for some sick looks.
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    figure i'll post this for ya... http://www.audizine.com/forum/showthread.php?t=102671
    check that out.. do what ya want. everyone here runs dif stuff. it's up to you to decide what you want. you dont want to have a car just like anyones on here.. or maybe ya do. they say stay away from ebay, but dont be affraid to just look. you would be suprised at what's there.. imo, that's the place to go for a test pipe @ $110. if u'r lookin for anything specific, SEARCH, then ask. there's lots of ppl here that love to help but they are only suggestions.. it's up to you what you want to do w/ u'r audi. be creative. mod your car they way you like it, dont not do something cuz someone says it's dumb or stupid. with that said, here is my opinion on what to do next.
    get that intercooler. it will help. anything to take the place of the factory smic is better. your intake is great... not worth changing. all this power is going to mean a new clutch sooner or later... start saving for a good one now. upgrade that dv pronto!! a piece that inexpensive that will save the life of u'r turbo?? a nobrainer..
    <--------yes, i used my audi to drag my deer out of the woods. it was heavy, i was cold, car had heat, much less work, and frankly, it was far. the deer was big, i am not, just seemed like the right thing to do. if it werent for the apr2+ i may not have been able to pull that monstrosity out of the woods w/out a helicoptor. i cant afford a helicoptor, i have a hard enough time affording my audi. all this being said, yes. that is an apr2+ awd audi pulling a deer out of the woods.
    Veteran Member Four Rings Undisputed's Avatar
    Jun 29 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    Quote Originally Posted by AudiA4Turbo22 View Post
    X2
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
