Results 1 to 18 of 18
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Smell coming from rear of engine...something to worry?
    Did a search and wasn't sure if I found the right posts.
    I have a "rubber-like" burning smell emitting from the rear of my engine. Also noticed a continuous flow of clear white emissions rising from my exhaust this morning.
    Is this something I should REALLY worry about? I've searched posts and some its my coolant leaking INTO my engine bay, but I check my coolant today and its still at max.
    2015 B8 SQ5
    Click Here
    Past
    Apr 05 2007
    Re: Smell coming from rear of engine...something to worry?
    check back of engine w/ a flashlight -- more than likely your valve covers or cam plugs are leaking a bit of oil.
    white smoke on cold start / warmup is fairly normal with these cars.
    Dec 02 2007
    DC/MD/(VA)
    Quote Originally Posted by exorcet View Post
    check. thank you sir.
    2015 B8 SQ5
    Click Here
    Past
    Veteran Member Four Rings KompMan420's Avatar
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    Agreed. I just changed the driver's side cam plug due to basically the same problem. It helps to get a little extendable mirror and remove the coolant resevoir to see it. Valve cover gaskets are pretty common. Also, FYI, if it's the valve cover gasket, you might as well do the cam plugs too while you're in there. The plugs are only a couple of bucks and if they leak later you have to remove the valve covers to get to them. Good luck
    SOLD - 2001.5 Audi S4 Twin Turbo ~ 450hp
    Mods - AWE/GIAC Stage 3 | AWE Intercoolers | STaSIS Coilovers | RS4 Clutch | 3" Borla Cat-Back | ASP DTS | JHM Solid Axles | "Piggie" downpipes | Neuspeed SS | AWE Pedals | IceLink for iPod | 710n DVs | M3 Spoiler | LM Reps 18x8.5 Satin Black w/red Time Attack
    www.NJSRealty.com
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Might want to also check the spider hose in the back.
    l gotta-- l gotta get
    a form from a scientist.
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Smoke / Smell from the rear of engine is usually a bad valve cover gasket(s) or cam tensioner seal(s).
    --Adam
    Have questions? E-mail me.
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    I have the same issue and can smell it in the car. I also see a little smoke coming from the drivers side of the engine when the engine first warms up. So, it's probably the valve cover gasket or cam tensioner seals? Anyone have a link to a diy? Thanks.
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    www.NJSRealty.com
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    yeah, every time I get an oil change I get a burning oil smell inside the cabin (whenever I come to a stop, or sit idling for a few seconds). For some reason it goes away after a few hundred miles, so it must just be getting a little too full. I've traced it back to the spider hose, which has a small leak that mists oil onto the firewall and PS-turbo. I just need to replace it one of these days...
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by Allaidback View Post
    check your PMs. did you ever figure out the Vag com issue?
    May 23 2008
    Columbia, SC
    yeah...I explained in the prior post. Basically just adjusted the port setting under device manager.
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    anyone have a detailed writeup for the cam tensioner seals?
    2010 Brilliant Black/Magma Red S4
    Sep 14 2006
    14 GLI
    ^ More detailed than the above links?
    Feb 09 2007
    00 S4
    MA
    just did them tonight...not that bad...
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
    May 22 2007
    East Bay, Ca
    Is there a trck to getting the driver's side plastic cam plug out?
    Registered Member Two Rings i5wikcedi3's Avatar
    Oct 05 2008
    2001 Audi S4 Stage 2+
    San Diego
    Same problem with me... replaced valve cover gaskets already, still smoking at warm up with a burning aroma in cabin but after its warmed up, nomore smoke in engine bay, or very minimal smoke but nomore smell. Can it be my cam seals? I did lose a little boost also...
    "Fear No EVO"
    GIAC Chip, AWE DP's w/ hiflow cats, AWE Twin 2 system, AWE DTS, AWE Boost Gauge, APR Bi pipe, EVO intake, 710N DV's, STaSIS T/S Suspension, Short Shifter, Euro headlights, RS4 clutch kit, 11 lb Fidanza flywheel, PowerStop D/S Rotors
    Senior Member Three Rings SilverThing's Avatar
    Dec 26 2007
    cars & stuff
    Long Island, NY
    Quote Originally Posted by i5wikcedi3 View Post
    Sounds (smells?) like your cam seals are leaking - got the same issue and will be getting it fixed next week Hopefully, when done, no more oil burning smell in cabin.
    Rides:
    '06 S4 Avant, silver/black w/ alcantara, w/ V8 goodness - new DD (finally back in an S!)
    '07 A4 Avant 2.0TQ S-line & Ti, I-white/black (unicorn?) - w/ APR goodness, old DD, now beach-mobile
    '93 BMW 850ci, FE Red/Black - major garage queen
    Previous:
    '01.5 S4 Avant, Silver/Onyx (Sold...miss it a whole lot )
    '98 BMW 328ic, Cosmos/Grey/Black (Sold...miss this one a whole lot, too)
    Oct 05 2008
    San Diego
    Thanks for the heads up SilverThing. Let me know if yours still smokes after you change out them seals.
    "Fear No EVO"
