Hey guys,
As many of you know I recently installed S6 LED's on my car. I had to shave the backs of the them down in order to avoid hitting the intercoolers. On one LED stip, the caulking did not take fully and it fogged up the LED housing. This is exactly the same as the CC mod and the caulking not taking so I figured you guys would be able to help me.
The fog and water has finally all disappeared and seems to have evaporated from inside the LED housing. If I caulk the whole now, if it gets hot, will any remaining water particles inside the housing be affected if it is finally air tight? I know some water particles are probably too small for me to see, so will I be ok to just seal it up now without having to worry that something already inside will be affected?
I assume it is ok to caulk again because people do the CC mod in all types of weather and the inside of the headlight is unaffected once the holes are clogged. But I just need some help to be sure. Thanks guys.
