Results 1 to 20 of 20
    Veteran Member Four Rings Dylan's Avatar
    Mar 28 2008
    1.8T TIP Weirdness?
    Since I've started using my Tiptronic more often, I've noticed that when I shift into 2nd, it's almost like there's a 1.5th gear.
    1st - rev up to ~4000, shift
    feel the kick, revs drop to ~3000 then go up to ~3500
    kicks again (without me shifting), and revs drop to ~3000 again
    Is this normal? It's definitely not, based on my limited knowledge of manu-matics, but I'm thinking it has to do with rev-matching so as not to kill the clutch.
    Any thoughts or advice is appreciated.
    BRING BACK GCC REP!!
    jason1st: If you just want a good job and to be able to take care of your family with a lot of security etc. Canada is a great place for that.
    If you want to crush your enemies, see them driven before you, and hear the lamentations of their women, then the United States is where you should be.
    (_|_) 4
    Dec 06 2007
    Re: 1.8T TIP Weirdness?
    do u have APR 1+?? that is ur torque converter locking up.
    -Kirk
    BetaAlphaTau Member #58
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    no no happens to me too.. as a fellow tipster.. i can tell you this.. its ur transmission module (ECU for ur trans) senses that ur RPM/engine speed is too low for 2nd grear so it completes 1st gear for u really quick then into second.. nothing to be worried about.. i know EXACTLY what u talking bout.. kinda pisses me off 2. =)
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    When you guys go BT, you'll appreciate the fact that the tranny does that.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Registered Member Two Rings
    Feb 07 2006
    ouellette
    mine does that too! It didn't used to do it though, which kinda worries me a little.
    Established Member Two Rings jpo's Avatar
    Jun 22 2008
    Calgary
    Weird, I thought I was alone!
    Dec 06 2007
    mine too that's what happens when we buy a car with the garbage transmission.
    -Kirk
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    ha, i mentioned this in another thread earlier today. but yeah, mine does it do. good to hear it's not the tranny starting to slip or something bad.
    Veteran Member Four Rings PDX04a4's Avatar
    Jun 22 2008
    2006 A4 Avant S-line
    SL,UT
    i experience something similar after shifting into 2nd. i usually shift before 3000 though, so i shift into second, in second the revs go up to ~2500-2600, then drop down to ~2100-2200 then proceed to go back up. as far as i can tell, its the only gear that happens in.
    Aug 26 2005
    Quote Originally Posted by AudiA4Turbo22 View Post
    Garbage transmission? If that is your opinion of the ZF trans in your Audi, you really are clueless here.
    Aug 26 2005
    Quote Originally Posted by Dylan View Post
    That extra bump after the trans shifts to 2nd, is the torque converter clutch locking up. When in tip mode, the TC clutch is locked up as much as possible so 2nd > 5th >1st is without TC slip in Tip mode.
    Dec 06 2007
    no no lol, they are not garbage, ZF makes some of the best trannies in the world, but by garbage i meant complicated and difficult to deal with when modifying.
    -Kirk
    Active Member Two Rings crizo's Avatar
    Aug 19 2008
    2004 A4 Ultrasport
    wilsonville, oregon
    So I just bought an 04 Ultrasport and I'm also noticing this odd behavior in mid 2nd gear. However..I swear it also does this in fully-auto mode. Can someone verify?
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    Quote Originally Posted by crizo View Post
    I agree, does it in D, S, and tip for me....
    Registered Member Two Rings bigbro's Avatar
    Jul 27 2008
    Black 05 b6 a4 1.8T Quattro AT
    Same here does it in D, or tip. My 98 passat did the same too.
    05 Triple Black 1.8T Quattro Tip.
    Aug 26 2005
    I thought I explained this already here, but maybe not.
    The "shift like" bump felt in second gear, is the torque converter clutch locking up after the 1>2 gear up shift. With the TCC locked, aka, "closed", the power flow is direct drive without any hydrodynamic slipping or other losses.
    Feb 06 2008
    03 a4 tip
    CAL, PA
    diagnosticator, I really appreciate the quality control. Yeah my ZF does the same thing and I have a modified trans and TC. That is just what it does.
    z
    Established Member Two Rings nwavant's Avatar
    Jan 25 2006
    19 Atlas R
    Olympia, WA
    Quote Originally Posted by RLB6 View Post
    BT?
    G.
    17 Allroad
    19 Atlas R
    00 Sportsmobile
    18 Tiguan (sold), 16 GSW (sold), 02 A4 Avant USP (sold), 04 VW Touareg (sold), 99 A4 Avant (sold)
    Dec 06 2007
    bt= big turbo and diagnosticator deserves a nobel prize
    -Kirk
    Feb 06 2008
    03 a4 tip
    CAL, PA
    for sure. He has helped me out alot with his posts.
    z
