Results 1 to 4 of 4
    Senior Member Three Rings jonsaudi's Avatar
    Jan 09 2008
    2003 A4 1.8T tip quattro
    California
    new brakes...brake fluid change necessary?
    I'm getting my front rotors and brake pads replaced (Zimmerman x-drilled, Hawk HPS). Now, is it necessary to get the brake fluid changed too?
    • 03 A4 B6 1.8T • Tiptronic • Brilliant Black • quattro • Sport Pkg //18" RS4 style rims //35% tint //Zimmermann x-drilled //Hawk HPS //CF wrapped trim.
    Veteran Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    Re: new brakes...brake fluid change necessary?
    No but you should just do it anyways while you're there. I replace my front rotors and pads the other day and just bled the brakes while I had my friend there helping me.
    Anthony
    Eurocode Tuning | fifteen52 | Speed Freaks Fabrication
    BetaAlphaTau Member #41
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Since you are not removing your brake lines it is not "necessary." Although it is always a good idea to change your brake fluid if it has been a while.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    should change them every 2 years for "normal" cars but while ur at it just change them. I recommend changing ur brake lines as well as that is important in brake feel - Goodridge stainless steel lines are very good
    CT4952
