Results 1 to 11 of 11
    Veteran Member Four Rings ExpLlclT's Avatar
    Nov 24 2005
    1998.5 Audi A4 2.8LQ
    Bay Area CA
    VAG'ed for my airbag and locks
    is this the pillar airbag or the in dash and how to i trace these wires if its in the dash ....
    airbag light cause:
    VAG-COM Version: Release 311.2-N
    Control Module Part Number: 8D0 959 655 M
    Component and/or Version: Airbag 7 Audi 0502
    Software Coding: 00104
    Work Shop Code: WSC 06335
    1 Fault Found:
    01218 - Side Airbag Igniter: Passenger Side (N200)
    32-10 - Resistance too High - Intermittent
    scaned my locks just to check if it had faults and something showed up
    no idea what this means because my locks are fine it was probly from previous ownership and no one cleared the codes not sure ?
    Control Module Part Number: 8L0 862 257 N
    Component and/or Version: CV-Pump D05
    Software Coding: 16200
    10 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Shareware Version. To Decode all DTCs
    35-00 - Please Register/Activate
    01374 - Shareware Version. To Decode all DTCs
    01370 - Shareware Version. To Decode all DTCs
    01369 - Shareware Version. To Decode all DTCs
    01368 - Shareware Version. To Decode all DTCs
    01366 - Shareware Version. To Decode all DTCs
    00991 - Shareware Version. To Decode all DTCs
    28-00 - Please Register/Activate
    00955 - Shareware Version. To Decode all DTCs
    09-00 - Please Register/Activate
    00956 - Shareware Version. To Decode all DTCs
    1998.5 Audi A4 2.8LQM is what i got.
    pm for photoshoot
    www.flickr.com/photos/explicitphotography
    Nov 24 2005
    Bay Area CA
    Re: VAG'ed for my airbag and locks
    anyone
    pm for photoshoot
    thats for the airbag in the seat. clean the yellow connector under the seat. clear the code. and see if it comes back.
    contact via email please.
    Veteran Member Four Rings Calabria's Avatar
    Dec 10 2006
    '00 1.8TQM
    LA
    I have the same code on my car, pass side airbag - resistance too high.
    (Ka-La-Bre-Ah)
    Nov 24 2005
    Bay Area CA
    Quote Originally Posted by k0mpresd View Post
    o thank god ill try this
    pm for photoshoot
    Nov 24 2005
    Bay Area CA
    how the hell do i get the yellow one off.... ?
    pm for photoshoot
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    Pull purple tab?
    "You know you have a bad idea when Ford guys are making fun of you."
    Nov 24 2005
    Bay Area CA
    know that for sure ? i hate breaking clips
    pm for photoshoot
    Apr 18 2007
    Orange Park, FL
    Well, it's definitely not the purple tab...
    Nov 24 2005
    Bay Area CA
    wel then what its just a cover thing still connected after that ....
    pm for photoshoot
    Nov 24 2005
    Bay Area CA
    well theres a little yellow tab between the black you push one way to get it off the black part and another purple tab on the bottom to unconnect the connection... but its through the yellow piece ... hmmm wonder how now.... ?? anyone ?
    pm for photoshoot
