Results 1 to 9 of 9
Thread: turbo whine
    Veteran Member Four Rings dcampana's Avatar
    Nov 01 2006
    04 Allroad, 01a41.8Q
    Nor Cal
    turbo whine
    For the past 3 days my turbo has been making a loud whining sound. I thin kthe turbo is going going gone.. I do not have any mods on the car, its a 2001 A4QT, with about 127k on the clock... TB was replaced at 100k, now the car does "smoke" at cold start up, but does not after the car warms up. I am thinking there is obvious oil bypass from somewhere, just at a loss.. If it is the turbo, what is the best bet? Cash is a bit low right now, so that has to be taken into account. I have about $500 or so to spend. Is it wise to limp around this way and save up more to get a ko4 setup? Or what do all the gurus think?
    Please help...
    On a side note, I lost the capability of using my remote key entry too, checked all fuses and replaced the battery and all... on top of it all, my turn signals dont work, flashers do though?
    Any and all advise is much appreciated!!!!
    I just want my car back, and then I NEED to make it move and its a true turd in stock form...
    Jun 08 2007
    GLI
    Orlando, Fl
    Re: turbo whine
    Used K03 turbo's can be found on this site in the classified section for around $125-200 depending on mileage. That would get you around until you scrape up enough cash for a K04 build. Just an option.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Nov 01 2006
    Nor Cal
    Re: turbo whine
    I will have to search for one. Thanks for th einput. How much work to go to a ko4? I am sure I will need supporting software? I was thinking of an APR upgrade but not sure...
    I really want o get the electrical figured out too:)
    Nov 01 2006
    Nor Cal
    Re: turbo whine
    BTW, thanks for the input A4Dit
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    Re: turbo whine
    Check your diverter valve first...
    APR 1+ | 380cc Injectors | APR TIP | FMIC | Snow Performance Methanol Injection | ATP 3" Downpipe
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    Re: turbo whine
    I use to live in windor haha.... anyway, check the Diverter valve and for boost leaks (look at the L shaped hose toward the rear of the intake mani)
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
    Nov 01 2006
    Nor Cal
    Re: turbo whine
    thanks phantom and gotaudi. I will get under the hood tonight and check those.
    Windsor- the arm pit of the wine country! hahaha
    I hope its the DV not the turbo... would you recommend upgrade to the 710?
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: turbo whine
    Stock DVs tend to fail when the car is chipped.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    Re: turbo whine
    upgrade toa K04, youll be glad you did.
    i did when my ko3 died
