Results 1 to 17 of 17
    Veteran Member Three Rings AudiHolicS4's Avatar
    Apr 16 2008
    Pasadena, MD
    Problem with coolant hose?
    Seems to be leaking coolant out the hose and onto the tank a little bit is this normal which i dont think is true but if not how hard to replace the hose? Thanks for all input
    2000 Silver S4
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: Problem with coolant hose?
    english?
    i have no clue what you are trying to say.
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Jun 14 2007
    2000 S4
    Connecticut
    no, leaking coolant is never *normal*. if you have too much it could come out of the OVERFLOW hose, but again, you're too vague have no clue what you exactly mean
    Apr 16 2008
    Pasadena, MD
    okay here is some pics to show the problem area im guessing the hose is just worn and def needs to be replaced take a look and give me your opinion heres the pics
    2000 Silver S4
    Apr 16 2008
    Pasadena, MD
    by the way thanks everybody for the help and also i checked the tank to make sure it wasnt cracked or anything and when i touch the dried up coolant it just peels right off and it seems to be coming from the hose as you can tell by the pics
    2000 Silver S4
    Senior Member Three Rings gaspeedracer's Avatar
    Jun 02 2007
    2001 Imola Yellow S4
    Daytona Beach, FL/Conyers, GA
    im thinking either the hose isnt clamped tight enough or the tank is cracked somewhere close by.
    "A true leader has the confidence to stand alone, the courage to make tough decisions, and the compassion to listen to the needs of others. He does not set out to be a leader, but becomes one by the equality of his actions and the integrity of his intent."
    -Douglas McArthur
    Semper Fi!!!
    Feb 28 2007
    chicagoland
    mine was doing the same thing.. didnt feel like the tank was cracked it was all smooth underneath.. take the tank off and i bet there is a crack.
    Nogaro 01 s4
    620whp 93octane
    Apr 16 2008
    Pasadena, MD
    okay looks like ill be working on it tomorrow so ill let you know how it goes and ill look for any cracks did yours look like it was coming out of the hose as well j/w
    2000 Silver S4
    Apr 16 2008
    Pasadena, MD
    okay well it looks like the tank is cracked on the bottom like JDM said its not a big crack but anyways it is a crack and does anyone know how hard that would be to change??
    2000 Silver S4
    Jun 14 2007
    2000 S4
    Connecticut
    Apr 16 2008
    Pasadena, MD
    is there anyway to install this without flushing the whole system i just had the timing belt and coolant replaced about 2000 miles ago dont wanna have to pay someone to change this if theres a way i can do it
    2000 Silver S4
    Dec 06 2007
    Calgary, AB, Canada
    Just disconnect one of the hoses directly below the tank and drain the coolant that is sitting in the tank. Then fix the problem. You don't have to drain the entire system.
    Feb 28 2007
    chicagoland
    i put some epoxy on mine
    been workin fine since. the cracks are honestlhy hairline.. normally wont leak until the sytem pressurizes.
    but il be replacing my tank as soon as i acn anyways.. im just saying if u need a temp easy fix grab some JB weld or some sort of strong epoxy
    Nogaro 01 s4
    620whp 93octane
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    you can do what jdm said but its probably best that you change it. Difficulty level on changing the part your self is the same as opening your door.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Apr 16 2008
    Pasadena, MD
    awesome thanks a lot everybody for the help im gonna put some epoxy on it for a short term fix but sounds like it should be easy to fix anyways with a new tank so once again thanks everyone
    2000 Silver S4
    Veteran Member Three Rings TheDarkness's Avatar
    Jul 13 2008
    15' A3 2.0T , b5 S4 Stage III
    i need to flush mine today, new to the car too...where is the drain hose located?
    Jun 02 2007
    you can drain the system from the radiator hose. thats how i did it. its on the bottom right of the car. theres a clip you need to pull from it
    -Douglas McArthur
    Semper Fi!!!
