Results 1 to 9 of 9
    Senior Member Three Rings theskuh's Avatar
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    got a vag-com cable and pulled 13 codes
    I am in limp mode now have been for a bit trying to figure out my issue.
    here is the laundry list.
    17833 P1425 Evap purge valve short to ground
    17525- P1117 O2 Sensor Heater Circ.,Bank1-Sensor2 Short to Ground
    Replaced front O2 sensor a bout a month ago.
    17843 P1435
    Sec.Air Inj.Sys.Pump Relay Circ. Short to ground
    17829 P1421
    Sec.Air Inj.Valve Circ Short to Ground
    17697 P1289
    Turbocharger bypass valve short to ground
    17880 P1472
    EVAP Emission Contr.LDP Circ Short to Ground
    16486- P0102
    Mass or Volume Air Flow Circ Low Input
    17523- P1115
    O2 Sensor Heater Circ.,Bank1-Sensor1 Short to Ground
    16518- P0134
    O2 Sensor Circ.,Bank1-Sensor1 No Activity Detected - intermittent
    I am guessing this is the heart of my problem?
    and last
    17522- P1114
    Bank1-Sensor2 Internal Resistant too High
    Maf is new and double checked, second o2 sensor is not though
    where do I go from here?
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: got a vag-com cable and pulled 13 codes
    Fuel Pump Relay
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    Just replace it? or is there a fix?
    Jan 21 2006
    6MT BT Avant Ti
    RI
    I'm pretty sure thats what is causing all the shorts. Its an encased circuit board, so if you want to mess with wiring diagrams and check each circuit, go ahead and start fixing or just buy a new one for like $40.
    Jul 28 2008
    Everywhere
    Where do i find a vag-com? If you don't mind me jacking your thread and asking
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    http://www.ross-tech.com/
    get a cable off ebay and their software for $99
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    Fuel pump relay is on its way. Thanks for pointing me in the right direction.
    Feb 27 2005
    North Wales, PA
    short to ground usually means a blown fuse. check those...cause its a free diagnosis. they are all also engine timing and engine control related so check those fuses. audiworld should have a fuse listing.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    My theory checks out with the 1.8T troubleshooting database on VWVortex.
    Check it out.
