I changed my timing belt over the past couple of days and last night was the test drive after it was all done. Everything seemed to be fine but when I turned on the AC the econ light stayed on. I pressed the button, and it went off as the button was depressed, but came back on when I let go off the button.
The only thing out of the ordinary I did during the tbelt change was when I swung the AC radiator down out of the way. Before I realized I could just swing it down I had started to unscrew the refrigerent line that goes into it (I did not realize that it was the AC line). When I saw the refrigerent start to leak, I immediately tigtened it back up so I dont thing I lost too much.
Also prior to changing my timing belt the water pump impeller was just spinning on the shaft so the car was overheating. I did not drive it long at all before I shut it down, but it did run pretty close to H on the temp gauge and the coolant low indicator came on. Not sure if this threw the car in some sort of limp mode with the AC.
I checked over all the connections last night but I was tired, maybe I missed a connection that isnt turning on the compressor, would this cause the ECON light to stay on. Either way I will run a VAG Diag when I get home.
Any help would be greatly appreciated.
