Results 1 to 3 of 3
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    Driving/shifting In TIP
    Is it ok to let of the gas shift up and then get on the gas again (like shifting in a manual car) when driving in tip mode? Or should I just shift without letting off the gas? I find if I shift like a manual the shifting is quicker to engage to the next gear, but if I shift with the accelerator down it takes about 3 seconds. I used the first method on my Jetta MKV, but I don’t want to risk killing the tranny on my B7. Thank you in advance for your input.
    May 20 2008
    2013 Passat TDI
    Re: Driving/shifting In TIP
    I cant be the only parson driving the B7 in tip. How do YOU drive in TIP?
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    doesn't really matter how you drive in TIP... just drive however you please. I have TIP... wish I didn't though.
