Results 1 to 22 of 22
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    Cleaning the engine bay
    Has anyone attempted to degrease/clean their engine bay? Is it even safe? And how did you if you did?
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    Re: Cleaning the engine bay
    I haven't done it on this car, but yes, it can be done on any car. I ALWAYS cover ALL of my exposed wires before doing so. Don't use a high pressure stream for it (such as that at a car wash), just soak it and use elbow grease. Simple Green is a good solution for de-greasing. To be honest, professional steam clean is the best way.
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
    Veteran Member Four Rings Six Speed Turbo's Avatar
    Feb 09 2007
    Hopes, Dreams, Tools, Car Parts
    Killeen, TX
    I would like to hear a second opinion on this, because I have heard different.
    2016 S3 Prestige - Glacier White Metallic, APR Stage 3+, APR TCU upgrade, APR CAI, APR FMIC, APR Catchcan, APR Lowering Springs, P3 Guage
    YouTube Channel https://www.youtube.com/channel/UC88...LbgXXvRHPvW3Xw <---SUBSCRIBE
    Jan 17 2008
    07 A4 Qtip
    Alberta
    I would second the part about not using a high pressure stream. I'm not 100% sure but my car started misfiring after I washed it and they had to replace the coil pack when I took into the dealership.
    Damn it, that's what I get I listen to my other friends saying oh no problem, I just pressure stream my trucks engine no problem..duh.
    Sep 19 2007
    seattle
    keep in mind steam contains small particles and they can get into some engine parts. I would post this in the detailing forum and let these guys answer it.
    May 20 2008
    2013 Passat TDI
    Quote Originally Posted by aphextwin2050 View Post
    Warranty??
    May 20 2008
    2013 Passat TDI
    I just called the stealer and they suggested steam over high pressure.
    Senior Member Two Rings reggaemylitis's Avatar
    Apr 19 2008
    06 A4 Avant 2.0TQM
    South Lake Tahoe, CA
    Search the Detailing Forum. There are tons of threads about cleaning your engine with products to use and metods. Oh, and pics!
    http://www.audizine.com/forum/showth...ghlight=engine
    APR Stage II. AWE Exhaust. AWE FMIC. Forge DV. JHM Short Shifter. RS4 Rear Sway. 034 Turbo Inlet Hose.
    "We're going to sodomize our vast imaginations with this pornography!" -Ignignokt
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    if the truck was a diesel... there should be no problem... or to the least very little problems to deal with.
    some cars seal the ignition system better than ours hence the coilpack failures (with or without washing them)
    Jan 17 2008
    07 A4 Qtip
    Alberta
    Quote Originally Posted by airborneriflema View Post
    Warranty??
    Yes, it was covered under warranty
    Senior Member Two Rings D-techniK's Avatar
    Feb 24 2008
    Miami Lakes, FL
    I grab plastic bags and cover electrical parts. (Alternator, throttle body, etc.)
    Even though the plastic where the ECU sits is water proof I find it easier to clean with a humid towel. (instead of spraying water directly.) Same goes with battery and plastics around it.
    I spray degreaser in the heavily grease/oil/dirt areas. Instead of using high water pressure I use the regular water hose's basic pressure. The difference in my method is I buy at either Home Depot/Walmart/Target those toilet scrub brushes which in some places go for less than a dollar and many of them can be turned or flexed into those hard to reach places. By using these brushes you don't have to spray your engine bay with high water pressure. These brushes are cheap so you can either clean reuse or throw it away.
    Hope that helps next time I do this I will post pics. Where I work looks like a rally track. (Car is clean only the weekend so under the hood gets pretty nasty)
    That picture gives you guys an idea of what I have to drive on. (My bro once hydrolocked his SLK)
    This was before they installed some basic sewers. Now instead of flooding half way up the car it floods half way up the door.
    Sorry for the long write up.
    Established Member Two Rings GEkido's Avatar
    Apr 25 2008
    Miami, FL
    ^That looks like da hood...
    2021 S5 Sportback | Glacier White | Sport Package | Black Optic | APR 93 Tune | APR FMIC | AWE CF Intake | 034 F.S.B. | 10/12.5mm Spacers
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Simple Green and a couple of rags. I use the same hose I use yo wash my car in some areas. Your bay shouldn;t be that dirty if you clean it regularly and don't go offroading.
    Feb 24 2008
    Miami Lakes, FL
    Quote Originally Posted by GEkido View Post
    If your from Miami then maybe you have heard of Medley. (Very industrial area)
    Our office is not ghetto at all
    May 20 2008
    2013 Passat TDI
    Quote Originally Posted by akaEsCo01 View Post
    I thought QUATTRO means off road in German, JKS.
    Feb 24 2008
    Miami Lakes, FL
    Feb 24 2008
    Miami Lakes, FL
    ttt
    Veteran Member Four Rings TDI's Avatar
    Nov 13 2006
    a4 avant B7
    Belgium
    i did it
    all meguiars stuff
    also added a couple of more OEM stuff
    Before
    between
    after
    water and soap
    meguiars quick detailer
    meguirs spray for tyre's
    and yes it stay's clean
    -God show me the way..because the devil try's to break me down-
    Kanye West
    Veteran Member Three Rings barkerd427's Avatar
    Oct 04 2006
    2007 Audi A4 & a honda
    Princeton, NC
    You have inspired me to do mine. I guess this will be another thing to add to my list to do on my Christmas weekend.
    2007 A4 2.0T S-Line Quattro / Deep Sea Blue / Black Leather Interior / Nav / Heated front seats / Xenon head lamps / APR Snub Mount / RS4 Pedal Set / RS4 brushed aluminum grille / RS4 rear sway bar / RS4 parking brake handle / Xenon match interior lighting / SOON Custom fog light grilles with S6 LEDs and RS4 mesh and brushed aluminum trim, just need to find the trim
    Junior Member Two Rings
    Oct 31 2008
    06 A4 Quattro 2.0t 6spd
    Abbotsford BC CANADA
    so i washed my motor last week. 2 days later coilpack failure lol
    i didnt use pressure either just soft stream... live and learn i guess
    glad i had audi roadside assistance.... free towing hehe
    Dec 14 2006
    2007 Audi A4 S-Line
    Long Island, New York
    I brought my Durango in to get detailed and they steamcleaned the engine compartment. I don't know exactly what they did but check engine light was on when I drove it home. lesson /learned
    Veteran Member Three Rings Tru NY Player's Avatar
    Apr 27 2007
    TIME MACHINE
    Tha M.I.A.
    Quote Originally Posted by D-techniK View Post
    hes right...not a good 'car' area
    'Leave sooner, drive slower, live longer.'
