Results 1 to 7 of 7
    Veteran Member Three Rings fritzner's Avatar
    Nov 30 2006
    05 Red USP Avant 1.8T 6spd
    Pittsburgh, PA
    what is the offset and hub diameter on B8 wheels??..
    crap, i just found a post by Achtung!ng debut the S5 replica for A5s.. it said the offset was 25 and would not work on a B6..
    an et 25 may just be for the rep or for an S5 setup.. the 5-spoke A5 above, may be different..
    >'05 Brilliant Red A4 USP Avant 1.8T 6spd
    ...REVO-II | TT injectors | RS4 sway | RS4 Pedals | podi
    ...Moven SP-10 (sportec reps) | 3.0L brakes | RNS-E | coolbox
    ...USP CLUB MEMBER #118
    Veteran Member Four Rings DeMOROlized's Avatar
    Sep 18 2006
    GTA Canada
    Re: what is the offset and hub diameter on B8 wheels??..
    For S5, 66.56mm hub, ET32 offset. I think the A4 offset is different, but hub is the same.
    1st Ring: 2002 Dolphin Grey B6 A4 1.8TqMS
    2nd Ring: 2006
    Moro Blue B7 A4 2.0TqMS
    3rd Ring: 2010 Phantom Black B8 A5 2.0TqM S Line
    4th Ring: TBD
    Nov 30 2006
    Pittsburgh, PA
    thanks..
    i tried to search, but "B8", "A5", etc are too short for the search..
    does anyone make hub rings??.. can someone make a set for me??..
    specifically i'm looking at fitting these on a B6..
    an et of 32 will sit pretty flush, but should fit.. i would guess 8", but i'll find out the width and offset for the specific rims for sure..
    Nov 30 2006
    Pittsburgh, PA
    well i just got off the phone with the Audi dealership and Achtun!ng and i got the answers i was looking for..
    the A5 5-spoke discussed in this thread is::
    18 x 8
    et29
    66.6 hub
    same ball-seat lug nuts
    achtun!ng sells hub rings for $5ea..
    using the offset calculator, it shows these rims would sit the same as Sables (18 x 8.5 x et30)..
    Veteran Member Four Rings doowopaudi's Avatar
    Aug 10 2011
    North Whittier
    I found a place near me that sells oem replica wheels on ebay, so I went to their shop to look at some 20" peeler replicas that I wanna get and saw on the box that the hub specs were 66.45. i told the guy that the audi A4 B8 hub bore is 66.6 and he said it was 66.45 and that they would fit the A4. he said he owned an A4 and now an A6 and he sells wheels for a living and that he knows they would fit my 2010 A4. I doubted him because I have read many posts here where forum members say our hub bore is 66.6. However, while I've read that our hub bore is 66.6, others have posted that it is exactly 66.56, but that you simply round off to 66.6. Another guy in the A4 B8 forum said the 2010 A4's have a hub bore of 66.45! See 4th post here:http://www.audizine.com/forum/showth...95km-h-105kn-h
    So which is it? And how can I know for sure? I called the dealer and they don't know so they got my number and said they'd call me back, but they never did! I looked in my car manual and those specs are not there either. Is it documented somewhere or is it all hearsay?
    Looking forward to finally settling this question. Thanks.
    In other words, will 66.45 hub wheels fit a 2010 A4 B8?
    ::2010 A4 Premium+ Quattro::6SMT::Meteor Gray Pearl Effect::35% 3M tint all around::Vag mods::debadged::RS4 replica grille w/ fog grilles::LED interior lights and lic. plate lights::ST Coilovers::19x9 OEM A5 Peelers::245/35/19 Achilles ATR Sport::Underseat Storage Bins::Zubehor Diffuser::Door Handle storage bins::LED reverse Lights::
    Former: 2008 A4 S-line::2007 Mazdaspeed3::1991 VW Cabriolet
    Veteran Member Three Rings AudiKerl's Avatar
    Jul 07 2012
    MN
    Don't think it would work.
    If you really wanted to make sure you can ask to test fit the wheel, might get lucky and he'll let you!
    Aug 10 2011
    North Whittier
    Quote Originally Posted by AudiKerl View Post
    That would be great, but unfortunately, this is a storage warehouse and they have no shop.
    Does anyone know where I can find the official documentation for our hub bore spec?
    I just called the guy again to clarify and again, he assured me that he's been selling wheels for Audi's for many years and that he's never had a problem. He said that even if it ISN'T a typo, 66.45 mm is not a big difference to 66.56 mm. Do you guys agree?
    Will .11 mm difference make a huge impact?
    If it does happen to be a typo and it really is 66.56, will the rest of the sizing info cause any issues? Will a 20x9, et35 be fine on an a4 b8?
