will B8 wheels fit on a B6??.. i tried to search, but "B8", "A5", etc are too short for the search..
i found some threads that said the hub diameter is larger.. so B8 wheels should work on B6 with hub centric rings.. but B6 wheels will NOT work on a B8..
does anyone make hub rings??.. can someone make a set for me??..
what about the offset??.. i saw 32, but not sure if that is correct..
specifically i'm referring to these..
an et of 32 will sit pretty flush, but should fit.. i would guess 8", but i'll find out for sure..
