Results 1 to 11 of 11
    Veteran Member Three Rings youngspeed's Avatar
    Jan 15 2005
    RS4 Avant, A4 1.8TQM Avant 05, EVO X 08
    Spot marked X
    Southbend 20lb Flwwheel. Anyone using it?
    Just bought the SB OFE SS(my second one) but now with the SB flywheel(my previous one used the stock FW).
    Anyone using it and some feed back please. TIA
    Btw bought it from Jeff Lee(audigeek) about the best retailer you can find on any forum, thumbs up to him!
    SQ5 B8 white
    REVO STG 1+ SINGLE PULLEY,APR CPS, APR 3.0T CARBON FIBER INTAKE, 034 THROTTLE BODY SILICON HOSE, 034 REAR ARB, 034 TRANSMISSION AND DIFF MOUNTS, KW V3 COILOVERS, AP RACING BBK, LEYO V1 PADDLE SHIFTERS.
    PAST RIDES - RS4 B7 MISANO RED. GIAC TUNED, MILLTEK.y
    2015 SUBARU WRX STI, ECUTEK TUNED.
    EVO X. ECUTEK, HKS EVERYTHING
    GTRS BT A4 1.8T TQM UNITRONIC TUNED
    A6 C5
    INTEGRA GSR
    Dec 25 2004
    Earth
    Re: Southbend 20lb Flwwheel. Anyone using it?
    I ran Spec's 240mm light-weight billet steel flywheel. It weighed in at 16 pounds....
    I had a couple issues related to the lighter flywheel. A nasty vibration which would make the gearbox sound like it was rattling apart, and I couldnt shift from 1st-2nd under hard excelleration. Plus my clutch pedal was all the way to the floor.... I removed the 240mm setup and installed SouthBends OFE HD. At the time, SouthBend did not have their flywheel available yet....
    From what I've read, the SouthBend flywheel weighs in at 20 pounds. The Spec LWFW I had weighed in at 16 pounds. I've been contemplating gettin the SBLWFY, but dont really want to find it brings back the same issues I had with the Spec's LWFW. The 4 additional pounds may reduce the vibrations, may not.
    My 2004 A4 1.8T Quattro has the 6-speed gearbox. The problems I had may not happen on 5-speed gearbox's...
    Jan 15 2005
    Spot marked X
    I am taking out my 12lb fw, i think my chatter is much worse then your 16lbs.
    Nobody else running the SB LWFW???
    SQ5 B8 white
    A6 C5
    INTEGRA GSR
    Dec 25 2004
    Earth
    Quote Originally Posted by youngspeed View Post
    12lb, is that the aluminum flywheel?
    x1rider over on Audiworld has the SB LWFW...
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by MikTip View Post
    Yes. The 9, 11 and 12 lbs flywheels are billet aluminum. The 15, 16 and 20 lbs are billet steel. Andy at SB told me he did the 20 lbs flywheel so that it would keep more momentum for people that like to drag race.
    Veteran Member Four Rings aLeXliu911's Avatar
    Sep 14 2006
    2003 A4 1.8T QM
    Vancouver
    i have eurocode tuning 's 11lbs Aluminum Flywheel and SB OFE SS for over a year, rattling is the only issue with it, everything else is good.
    BetaAlphaTau member #11
    2003 A4 1.8T 5SpdMQ Black
    545awhp, 477.4awtq
    Stasis Motorsport C/O
    Stasis Center Diff
    Stasis Rear LSD
    Stasis Alcon BBK
    Status Carbon Fiber Seats. ER Comp FMIC
    2008cc, AWM, Ported AEB Head, HTA GT3582R,Full Race Exhaust Manifold, INE Intake Manifold
    Jan 15 2005
    Spot marked X
    yup think its alu
    SQ5 B8 white
    A6 C5
    INTEGRA GSR
    Veteran Member Three Rings 05A$SE's Avatar
    Feb 12 2008
    05 A4 1.8T Special Edition
    Dirty Jersey / Phoenix
    im running the 12lb FW and the only time it chatters is under 2200rpm on stock mode. and about 1900rpm when i have it on stage one. when the car has boost it doesnt make a noise really. i hear light noise with the a/c on at a dead stop but its only heard if the window is down or your outside the car then it sounds like a tdi. i like my lwfw but next time i'd probally go for a 16lb. it doesnt seem to have the momentum that the stock fw had. its quicker right away but in the long run i'd rather have the momentum its pretty hilly terrain around me.
    2005 DG On Black Special Edition 1.8T 6MT
    Built 2.0L Stroker, ETC
    2012 C63 AMG - 600HP and counting
    2006 Corvette - GTR (1 of 7) - Blue One on GOOGLE
    1998 H1 - AM General 4dr Hardtop
    1992 M998 - Slantback Project
    1990 240SX - big turbo drift missile
    1989 K1500 - LQ4 6L90 Swap
    1986 RX7 - Truck conversion, LS1, 72* angle kit
    Veteran Member Four Rings AudiHere04's Avatar
    Nov 21 2005
    568HP%20FWD%20A4
    East Coast
    I have the 20lb SB LWFW on my car right now, no noticeable chatter. Car is also revving a lot faster.
    Buy My Parts!
    Precision 6262 Turbo needs a core - $800
    B6 Thule Evo Roof Rack - $300
    Jul 07 2004
    socal
    Hey guys in case you missed a post of mine on another clutch thread.
    After talking to andy/john at Southbend last week , they told me they are now going to offer a 17 lbs billet steel flywheel and also dropping the retail price of the A4 steel flywheels down to $399. That now brings them down to right around the same price as the Spec 15-16 lbs flywheel.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I was thinking last night about my 1/4 trip 2 weeks ago. I can't get my car to launch with the 7200 file and I think I figured out why. I'm running a 11lb. alum. FW, lightweight knife edged crank and alum frt. pulley. I've plobably shed about 25-30lbs off my rotating assem. and all the inertia that comes with it. I'm shipping my ECU back to Revo in the morning for the 8500 file.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
