Results 1 to 4 of 4
    Veteran Member Three Rings fritzner's Avatar
    Nov 30 2006
    05 Red USP Avant 1.8T 6spd
    Pittsburgh, PA
    will B8 wheels work on a B6??.. offset and hub diameter??..
    will B8 wheels fit on a B6??.. i tried to search, but "B8", "A5", etc are too short for the search..
    i found some threads that said the hub diameter is larger.. so B8 wheels should work on B6 with hub centric rings.. but B6 wheels will NOT work on a B8..
    does anyone make hub rings??.. can someone make a set for me??..
    what about the offset??.. i saw 32, but not sure if that is correct..
    specifically i'm referring to these..
    an et of 32 will sit pretty flush, but should fit.. i would guess 8", but i'll find out for sure..
    thanks ..
    >'05 Brilliant Red A4 USP Avant 1.8T 6spd
    ...REVO-II | TT injectors | RS4 sway | RS4 Pedals | podi
    ...Moven SP-10 (sportec reps) | 3.0L brakes | RNS-E | coolbox
    ...USP CLUB MEMBER #118
    Nov 30 2006
    Pittsburgh, PA
    Re: will B8 wheels work on a B6??.. offset and hub diameter??..
    crap, i just found a post by Achtung!ng debut the S5 replica for A5s.. it said the offset was 25 and would not work on a B6..
    an et 25 may just be for the rep or for an S5 setup.. the 5-spoke A5 above, may be different..
    Nov 30 2006
    Pittsburgh, PA
    For S5, 66.56mm hub, ET32 offset. I think the A4 offset is different, but hub is the same.
    just got this from a different thread..
    Nov 30 2006
    Pittsburgh, PA
    well i just got off the phone with the Audi dealership and Achtun!ng and i got the answers i was looking for..
    the A5 5-spoke discussed in this thread is::
    18 x 8
    et29
    66.6 hub
    same ball-seat lug nuts
    achtun!ng sells hub rings for $5ea..
    using the offset calculator, it shows these rims would sit the same as Sables (18 x 8.5 x et30)..
    but the OEM tires are 245/40/18, so they may be a bit too big.. but the rims "should" work..
