Results 1 to 10 of 10
Thread: Random Boost...
    Established Member Two Rings DubAudi3's Avatar
    Aug 14 2007
    01 a4 1.8tqms
    Canton, CT
    Random Boost...
    I have an 01 A4 1.8T
    revo software
    ghl turboback
    710n dv
    evoms cold air
    Randomly ive been hitting low boost numbers like 10psi spike and last week it was hitting 5 lbs spike... unplugged the battery for a few minutes and its back around 22lbs... no idea why this is happening... i have the "mooing" sound from my engine bay around 0 (no vac or boost) but other than that it runs perfect... and last i checked a few weeks ago i didnt have any boost leaks... any ideas? Kinda new to the 1.8T motor
    01 A4 1.8T QMS
    www.BishopMotorsports.com
    Canton, CT (PM me for details)
    Dec 05 2007
    Re: Random Boost...
    Maybe you need to contact Revo Technik about this issue. Sounds more like a software issue with your ECU if you were to reset your ECU (via battery) and have it run normal with no boost issues spiking ~22psi.
    Aug 14 2007
    01 a4 1.8tqms
    Canton, CT
    Re: Random Boost...
    Yeah i will do that... car went into limp mode tonight 5lbs of boost, then CEL after 10 minutes... then randomly went back to full boost again..
    01 A4 1.8T QMS
    Dec 05 2007
    Re: Random Boost...
    Maybe you have some old fault codes on your ECU also and the software is sort of throwing your ECU into a loop. You can go to Autozone and use thier scanner to see if it pulls anything up. If it does, erase them and see if problem persists. (Vag Com would be better option though)
    Aug 14 2007
    01 a4 1.8tqms
    Canton, CT
    Re: Random Boost...
    P1128
    Long Term Fuel Trim mult., bank 1
    system too lean, sporadic..
    This came up when i had a guy in our shop check the code, he told me to check for vac leaks, and if not that then it needs a MAF
    01 A4 1.8T QMS
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: Random Boost...
    These MAFs should be recalled on 2001. They just keep going out.
    Seerlah, sell your spare to him.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Aug 14 2007
    01 a4 1.8tqms
    Canton, CT
    Re: Random Boost...
    hahah.. i work at a vw dealership my cost on one off a passat is about $127..
    01 A4 1.8T QMS
    Dec 05 2007
    Re: Random Boost...
    I'll sell you one for cheaper.
    FWIW, I have a boost leak and my MAF is just fine. Boosting around 17psi and I should be ~22psi (waiting for air compressor delivery to find leak). If you had a leak, you just would not be boosting as much as you should. And seeing how you are sporatically getting 22psi, there might be a different issue involved. Maybe the MAF as you and Nebone22 suggests.
    Try some CFC MAF sensor cleaner from Autozone before you dish out the $127 for a new MAF.
    Active Member Two Rings NewFisher's Avatar
    Feb 04 2008
    To much Ish!
    Re: Random Boost...
    [QUOTE=nebone22;2789965]These MAFs should be recalled on 2001. They just keep going out.
    AMEN!
    Never know unless u Try!
    Aug 14 2007
    01 a4 1.8tqms
    Canton, CT
    Re: Random Boost...
    haha .. changed a vac. line and cleared the codes.. doing a boost leak test at some point this weekend before i get a new MAF
    01 A4 1.8T QMS
