Results 1 to 12 of 12
    May 30 2008
    miami
    eibach pro springs vs s line suspension
    i am wondering how much of a drop will eibach pro springs give me over sport s line suspension it says 1.2" on the website but i dont know if the s line springs are already lowered to begin with
    Registered Member Two Rings KOU's Avatar
    Jul 30 2008
    '08 Ibis: S-Line ext & SE pack
    Re: eibach pro springs vs s line suspension
    ^ If you decide to switch out your s-line sport suspension (PM ME)...i'll be glad to take them off your hands depending on the mileage used on them...
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    subtract the difference between a sline and stock suspersion to the 1.2, and that;s how much lower you'll be with the springs you want
    TEAM|AXION
    Established Member Two Rings Ibis-Titanium's Avatar
    Jun 01 2008
    Grand Prairie, TX
    I just dropped my car on the Eibachs(from sport suspension) about a month ago. I did not take a before measurement, but the post installation measurements are as follows: Front fender measures 25 3/8"; Rear measures 25". Ideally the front would be a tad lower, but all in all the Eibachs gave it a nice, conservative, yet noticeable drop. It is perfect for me, because I work out of my car, so I wasn't looking to slam it. They provide a nice combination of a lower, more aggressive stance, while retaining much of the factory ride quality, and I don't worry about scraping my DTM splitter on every drive approach I encounter. Just my .02...
    Former: '08 Ibis White Ti-Package A4 2.0T Quattro 6MT S-line. DTM Front/ APR HPFP/ Unitronics HPFP Software/ AWE FMIC/ RAI 3" DP/ Okada Coils/ RAI Catch Can/ Vast Clutch/ BFI Snub/ TT S-line FB Steering Wheel/ OSIR/ Eibach/ 18" GM VMR V710/ Michelin Pilot SS/ JHM Short Shifter/ S4 2Pc BBK/ Blackout Rings(F&R)
    Veteran Member Four Rings Bllzll's Avatar
    Jun 09 2008
    b8
    also keep this in mind. i believe that the springs will lower it X amount. but if you use bilstein or eibach shocks or whatever, those shocks are also about a half inch shorter than your sline shocks. so on top of the springs lowering it, the shorter shocks also give it another half inch.
    i think eibach says its .45" lower than sline, but most people say its actually ~1.25"
    i dont know this from personal experience though, just from the many threads i have read about it. but i plan to put these on very soon
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    Quote Originally Posted by Bllzll View Post
    what??? shocks are only dampening the ride and do not affect the height.
    Mar 26 2005
    Quote Originally Posted by ibiski View Post
    they do if your shocks are grooved or adjustable :P
    TEAM|AXION
    Jun 09 2008
    b8
    honestly you could be right, because i really am no expert by any means at all..
    but i was JUST at the audi dealership talking to one of the parts guys and he was telling me that aftermarket shocks are about half and inch shorter than the sline shocks and that this also causes the car to lower a bit more.
    so basically he was saying that eibach springs/bilstein shocks would sit lower than eibach springs/sline shocks
    Apr 18 2008
    Jacksonville, FL
    um...alright...what y'all might be thinking about is that in the front, the springs do rest on the shock's threaded collar. this collar is adjustable, which may have confused some people about having shorter "shocks".
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    May 21 2008
    They might be, but that's only so they match up better with lowering springs. The car sits on springs, not shocks.
    Jul 30 2008
    does anyone know the Part Number's for the S-Line Sport Suspension (Springs & Shocks)?
    thanks
    Veteran Member Three Rings jayphil82's Avatar
    Apr 05 2008
    Quebec, Canada
    I would say that the shock will mostly affect the front height only. Why? Because in the front we actually have struts (the spring is around the shock and sit on the shock base). Depending on the shock the base where sit the spring could be slightly lower or highier than OEM...
