Page 1 of 4 123 ... LastLast
Results 1 to 40 of 121
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    GT3071r log. A little nervous....
    Well I fixed my laptop so I could then go do a log. I ran 21psi and timing 9 with Revo GTRS file with 440cc injectors and I have a brand new STOCK fuel pump as well just replaced under the recall like 2 months ago.
    Dont know how to log for injectors to see if they are maxed or whatnot but that air/fuel looks a little lean to me.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Feb 17 2005
    Sarasota, FL
    Re: GT3071r log. A little nervous....
    Requests are good, 12.1 but yup definitely leaning out up top
    Jun 30 2007
    Raleigh, NC
    just to refresh my memory - you multiply the lambda value by whatever A/F you see at idle right? with the ideal being 14.7 right?
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Apr 24 2005
    E55 AMG, CTS-V
    am I reading it wrong? The first column is the actual air/fuel right? and in the 1st gear (2nd gear) at 6800 it was .88 and then it was .87 and .89 alot through the next gear (3rd gear) and then the final gear (4th gear) was .88 and .92
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    What is your idle A/F? Take your idle lambda and multiply it by 14.7 to figure out your baseline A/F. So say your idle A/F is .870, 14.7x.870=12.79, now take your in boost lambda and mulitpty it by that 12.79. So say your in boost lambda is .899, 12.79x.899=11.50, that would be your true A/F.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jun 30 2007
    Raleigh, NC
    ^thank you for answering that
    what are you seeing at idle david?
    The Awesome™
    Apr 24 2005
    E55 AMG, CTS-V
    gonna have to go check idle a/f, but I thought that was pretty damn lean. WTF!
    ~David~
    CTS-V 9.6@148
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    This has gotta be on meth.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Apr 24 2005
    E55 AMG, CTS-V
    I thought that I saw it say like 1.2 or something before i took off before when still sitting at my house. Now it is saying 1.0 in both columns
    ~David~
    CTS-V 9.6@148
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by dirtybrd View Post
    That definitely wouldnt work on my car, my car idles around 10.1-2 or .69-.70
    .70*14.7= 10.29
    I get .90-.93 on higher boost (13.2-13.4 on the wideband)
    .90*10.29=9.2
    Doesnt work
    Apr 24 2005
    E55 AMG, CTS-V
    Quote Originally Posted by RLB6 View Post
    yes
    ~David~
    CTS-V 9.6@148
    Feb 17 2005
    Sarasota, FL
    David, GET A WIDEBAND!!!! Some of you trying to push the limits of these files while staring at a computer ripping through gears just doesnt work anymore. With some of the things Ive seen on the wideband with my car, if I was relying on looking at a log later on, my car would have blown up quite a few times!
    Mar 21 2006
    Lakeland, FL.
    Quote Originally Posted by A4ringedONE8T View Post
    .70*14.7= 10.29
    .90*10.29=9.2
    Doesnt work
    This will only work on Maf'd cars.
    I'm back bitches!
    Feb 17 2005
    Sarasota, FL
    Ive ran my car on a MAF, idle A/F goes up to 10.5-10.6, those calculations still wouldnt work
    Mar 21 2006
    Lakeland, FL.
    Well your cars just sucks
    I'm back bitches!
    Apr 24 2005
    E55 AMG, CTS-V
    I didnt figure I was pushing anything. You ran way more boost and timing 6 or 7 on this file and 440/430 injectors didnt you?
    ~David~
    CTS-V 9.6@148
    Feb 17 2005
    Sarasota, FL
    I agree
    Jun 30 2007
    Raleigh, NC
    ah.. MAF ftl.
    anyone know if I can hook up a wideband gauge to my stock wideband o2? hahaha.
    guess its time to get ANOTHER wideband sensor/gauge (wouldn't have sold my last one if i knew i'd end up needing it... )
    The Awesome™
    Mar 21 2006
    Lakeland, FL.
    What about your boost issue?
    I'm back bitches!
    Apr 24 2005
    E55 AMG, CTS-V
    My car doesnt run for shit with the maf undone. I get like 5 for vacuum and it misfires.
    ~David~
    CTS-V 9.6@148
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by A4 TSCHUSS View Post
    3071R on a GTRS file ... thats pushing it IMO
    27psi, T6, pump and meth. This was also on a built bottom which is a bit more forgiving than the stock rods
    Apr 24 2005
    E55 AMG, CTS-V
    I turned the timing down to 3 the other day and ran 25psi to 7000rpm so I dont believe I have an issue.
    ~David~
    CTS-V 9.6@148
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by B6Lovin View Post
    ah.. MAF ftl.
    Yes you can, you cant share one with the ECU though. FYI, only the front sensor is wideband, the rear (cat efficiency) 02 sensor is narrowband 4 wire
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Shawn you are my savior! Ive thrown that into posts many times, just to have oem wideband guys say its an accurate method to multiply voltages... ITS NOT... Get a dead nuts accurate gauge, with live feed... Ive had to rebuild my motor once due to running lean, hopefully it doesnt take that to get thru to you guys, Id hate to see that
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    wideband can be your best friend david... at this point im supprised you don thave one!
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Mar 31 2004
    CA
    Quote Originally Posted by 317ssayzarc View Post
    +1000
    Veteran Member Four Rings bananas's Avatar
    Jun 13 2005
    1999 A4 Avant 1.8TQM
    Minnesota
    What do you mean by this? What does who say about voltages?
    '03 A4 1.8TQM 337WHP/355WTQ (93+meth) | My car's Mods | Fancy Pants™ Turbo Club Member #001
    Oct 27 2007
    In the lab
    Lambada voltages times 14.7... like .871 x 14.7 = 12.80 AFR... This is not a proven way to check afrs and it can only be checked after a run, not during when it counts... Until someone gets a wideband and logs the wideband gauge, then compares it against the other method, Im a not believer... Sorry
    Feb 17 2005
    Sarasota, FL
    I couldnt agree more! An instant read and displayed wideband within view should be a necessity with any BT and especially BAT setup
    Another FYI, anyone with REVO BT, take your rear 02 sensor out, hook it up somewhere safe (remember the heater circuit is still active), other than that, it does nothing. Put a wideband sensor in the rear spot with a gauge and your good to go, no welding needed
    Oct 27 2007
    In the lab
    Another FYI, anyone with REVO BT, take your rear 02 sensor out, hook it up somewhere safe (remember the heater circuit is still active), other than that, it does nothing. Put a wideband sensor in the rear spot (if you have no cat) with a gauge and your good to go, no welding needed
    added a bit
    Mar 21 2006
    Lakeland, FL.
    I'm confused on how 12.1 is lean. Under 14.7 is rich and over is lean, right? 12.1=rich 15.2=lean
    I'm back bitches!
    Oct 27 2007
    In the lab
    no...
    under WOT you want high 11's real low 12's for boosted cars
    Mar 21 2006
    Lakeland, FL.
    I get confused, I don't work on any turbo cars and get N/A and boosted mixed up. For everyone else, we want ~.8xx under boost.
    I'm back bitches!
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    A/F is safe for race gas or a very good H20/meth blend. Timebomb on pump gas.
    Log 032 and look to see what your fuel trims are. 440s may be a tad bit small for the 30-71
    Apr 24 2005
    E55 AMG, CTS-V
    But im not pushing it! I have the 630cc injectors sitting here, I just wanted to wait for the GT30 file to work correctly since apparently there was a complaint from 1552 and ecode for having poor rich idle.
    I think there is no way im making more power right now at 20-21psi and timing 9 on the 3071 compared to with the GTRS. I could be wrong though but I dont think I notice a difference, so I dont see why the injectors could be tapped out or what the problem is. I just got my laptop working so I need to log some more. I will do that after work tomorrow and it will be on 19-20psi.
    Guess I need to ask a friend with an iphone to buy the dynolicious thing and run some 1/4 mile runs and see what it says.
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    When I asked about the boost issue, I was refering to the late boost, any updates?
    I'm back bitches!
    Apr 24 2005
    E55 AMG, CTS-V
    O gotcha. I havent messed with it yet. I start working at 7am and then get off around 5 and go to the gym from 6-7 roughly so I havent really had time.
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    I've seen you, the gym's not helping invest that time in the car.
    I'm back bitches!
    Apr 24 2005
    E55 AMG, CTS-V
    o please, I think you have me mixed up with Shawn Im built!
    And I look a little different than that pic from 3.5 years ago with the "tree man" im sure you are talking about.
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    LOL!!
    I'm back bitches!
