Results 1 to 4 of 4
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Foglights removed - disabling dash warning.
    Didn't find much on a search. so here is my question: my fogs are out and i'm kinda annoyed by the dash warning that the two fogs are dead/blown/missing when i start the car, is there anyway that i can VAGcom it so that it doesn't check for the fogs?
    Thanks,
    Phil
    Jun 08 2007
    GLI
    Orlando, Fl
    Re: Foglights removed - disabling dash warning.
    If you have the bulbs and they work just plug them in and ziptie them (the harness) to the inside of your bumper. I removed mine for my aftermarket bumper install and did this the other day to avoid your same problem.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Just remember to not turn them on. You can solder in resistors also.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jun 08 2007
    GLI
    Orlando, Fl
    I thought about using resisitors but don't trust it for long term use.
