Results 1 to 21 of 21
    Jul 28 2008
    Everywhere
    Do All Turbo Cars Burn Oil
    I am wondering if all turbo cars burn a bit of oil? My mechanic told me but another guy said they do not.
    Thanks
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Re: Do All Turbo Cars Burn Oil
    My oil level stays exactly the same every oil change. I check it a few times between changes.
    I'm at 66k miles.
    Feb 27 2005
    North Wales, PA
    i never really had a noticeable issue. but all cars consume SOME oil...just not at noticeable levels.
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Quote Originally Posted by Poopie View Post
    Yup those who say 1.8t's eat alot of oil have issues directly related to poor delivery or pickup. My stock 1.8 and my built 2.0 never vary a noticable amount really.
    Jul 28 2008
    Everywhere
    Yea the oil hasn't gone down but my car smokes? does that sound right?
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Quote Originally Posted by Junaid View Post
    That could be a bad valve guide dripping a little bit into the combustion chamber.
    I've got a bad PCV "puck" valve that is dripping a little oil in front of the turbo so it smokes and stumbles on startup and is sometimes hard to start. Other than that obvious problem it hasn't ever burned any oil.
    Jim
    I Do Werk.
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    No, they do not.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Jul 28 2008
    Everywhere
    Quote Originally Posted by onemoremile View Post
    I think i am in the same boat as you, my PCV valve might be clogged or leaking, i will have my mechanic check it out or is their is way i can do it myself?
    Thanks
    Established Member Two Rings FIRE's Avatar
    Nov 20 2006
    Guatemala, C.A.
    They don´t, and if they do, it´s just not noticeable...
    Streetracers...we know streets better than the bitch on the corner
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Thanks
    Time to change mechanics and get a technician.
    Some of the guys that build race engines claim that their engines will use more than a normal amount of oil. This is b/c they build them "loose" in comparison to a OE setup.
    As far as how much oil you're using, that kinda depends on the engine's condition. Rule of thumb is 1qt used per oil change. Personally I don't like to see more than 10% of the capacity burned off during the 3K between LOF's.
    Established Member Two Rings acollicott's Avatar
    Nov 13 2007
    2000 A4 1.8TQM
    Daytona Beach
    You shouldn't burn too much oil, most people can't see a drop between oil changes
    00 A4 1.8TQM | Santorin Blue | GIAC | Forge 007P | Pioneer AvicD3 | Southbend Stage III | N75 Race | Swiss Cheese Airbox | Boost Gauge | Sport Suspension | Windows Tinted | HIDs |Custom TI Package |
    Dec 14 2006
    Halifax, NS, Canada
    I used a little when I was using Castrol Syntec. Since I have used the ELF I haven't noticed any oil usage. My Dads brand new Passat wagon 2.0T was down 1.5L the other day after only having the oil changed at the dealer 2 months ago. They told him its normal... right.
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Established Member Two Rings twofaze's Avatar
    Jul 27 2008
    Fort Worth, Tx
    Quote Originally Posted by Squarrl View Post
    that doesn't sound right....
    some gasket or something must be aligned wrong or something for that much to be burning...
    Dec 14 2006
    Halifax, NS, Canada
    its got like under 10000miles on it. If it breaks its covered, thought it was odd.
    NOW DEAD :(
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    garage ornaments
    southeastern pa
    mine dosent burn a drop of oil even at 153k
    -Nic
    My Car
    old junk new junk, red junk blue junk
    Jul 28 2008
    Everywhere
    Okay so today i found out why my car was burning oil, my turbo might be going. I found oil in the pipe that goes from the engine to the turbo, or intercooler. That is definately not normal correct?
    Thanks
    Nov 06 2006
    garage ornaments
    southeastern pa
    some oil in the intercooler and pipes is normal... excessive amounts is not normal
    -Nic
    My Car
    Jul 28 2008
    Everywhere
    I am not sure how much oil is in the intercooler but in the pipes is a fair amount.
    Feb 27 2005
    North Wales, PA
    thats usually a sign of a bad pvc.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    thats usually a sign of a bad PCV
    Fixed. and what he said.
    Jul 28 2008
    Everywhere
    Thanks guys i really appreciate the answers my car is at the dealership to check the timing belt per the recall, i told them about the smoke and they said dont worry about it they will check into it, so hopefully they will find out.
    Thanks again
