Results 1 to 13 of 13
    Oct 30 2006
    B8 A4 Avant 6spd
    Telling a 2000 1.8t motor apart from 2001 visually
    I'm looking at a car that had its motor replaced (2001 A4), the head of the motor is prolly re-manufactured as there is no engine code on it. I need to be sure that the motor in the car is a 2001 motor as if I pick up the car I want the newer block to go 2.0L.
    Apperently one way to tell is by the water pump and the other is by looking at the block stamp. I cant see the block stamp, id have to remove the intake manifold and clean up the block to see it.
    If anyone can provide detailed pictures of a 2001 motor and also a 2000 motor that'd be awesome.
    -18 718 GTS
    Feb 27 2005
    North Wales, PA
    Re: Telling a 2000 1.8t motor apart from 2001 visually
    if its a 2001 a4, then most likely it has a 2001 motor. The coolant lines are slightly different and the engine mounts are slightly different from what i observed so swapping in a atw into the awm would be too much of a challenge to even attempt.
    Feb 27 2005
    North Wales, PA
    but to take a quick look...the water pump is in a seperate housing off the block in the atw. If the thermostat housing looks really hard to reach then you have an awm....if it looks like you can crawl under the car and reach it then its most likely the atw.
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    Motor replaced??? maybe they just replaced the head... My friend has a re manufactured head with no engine code stamp but it does have a part number on the head. Try to look for a part number on the head that should lead you somewhere...
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Look under the IM and the thermostat housing will be right under it to the left of the knock sensor. The head is a AWM head f you see a connector on the cam chain tensioner (could be a head of a B6 too that way)
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    Remove the top timing belt cover (it's 2 clips). The water pump will be on the right side right by serpentine belt tensioner. That's how you will know it's an 06A block. As for the head, it will either be a large port (non-VVT) head or a small port (VVT) head. Just check behind the head for the VVT solenoid.
    "You know you have a bad idea when Ford guys are making fun of you."
    Quote Originally Posted by chris164935 View Post
    not all small port are vvt. and vvt is only part of the tensioner. you can make a large port head vvt.
    contact via email please.
    Jun 04 2004
    fairfield cnty, CT
    -coil packs different
    -pcv venting from VC only on awm
    -VVT solenoid sticking off the CCT
    those are the top 3 easiest ways i can think of.
    Apr 18 2007
    Orange Park, FL
    Quote Originally Posted by k0mpresd View Post
    True, but I've never seen someone using a large port head and it didn't have AEB stamped on it.
    Oct 30 2006
    B8 A4 Avant 6spd
    Figured it out today in the sunlight, last night I was looking at it in a dim garage in the middle of the night. Its an 01 motor, which I am happy about =).
    -18 718 GTS
    Oct 30 2006
    B8 A4 Avant 6spd
    Quote Originally Posted by gotaudi View Post
    Yeah spoke to the owner, its a new block and a remanufactured head. No idea what happened to old motor.
    -18 718 GTS
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by ModifiedA4 View Post
    One big problem, the bolt down coil packs from the 2000 can be used on the 2001.
    there are several other large port varieties out there. they are not all aeb. look harder.
    and you never mentioned anything about engine codes. you said look at the tensioner. that will tell you if its a small port or large port. haha. whatever man.
