Page 1 of 3 123 LastLast
Results 1 to 40 of 105
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Talking The 19 Hour AWM Engine Build
    Got the engine built at 4am on Sunday morning. Everything started right up with the exception of two connectors that we forgot to plug in but after plugging them in the car has been running like a champ.
    So far I have only received one CEL for my SAI system which I get every few months so I just cleared it out and all is well again.
    Had a minor scare today when the car stalled out on the the road but it ended up being a loose intercooler pipe blowing off.
    So far I have put over 50 miles on the build and it is working great. The southbend stage 5 clutch feels so much better than the stocker and I'm not sure if it's just me or not but the car feels stronger than it did before the re-build even just after 50 miles.
    Can't wait to get all the bungs and piping welded up so I can swap out the turbo and get this show on the road.
    P.S. - The chatter from a LWFW is definitely not bad for anyone on the fence about getting one. This is my daily driver and I am very surprised how quiet the chatter is.
    Anyway here are some photos for everyone:
    The parts:
    My car with the Poopster starting the surgery on my car:
    The engine:
    My naked front end:
    Just the block:
    Another shot showing all the carbon keeping compression on the two outside cylinders:
    My stock clutch:
    Still tons of material left on it:
    The head & turbo:
    The block w/out pistons:
    The cylinder walls:
    The old hardware:
    A close up showing the carbon loving pistons:
    The stock piston all cleaned up:
    The engine back into the car sometime in the wee morning hours of sunday:
    Apr 10 2007
    Eastern PA
    Re: The 19 Hour AWM Engine Build
    Many thanks to Poopie and Bassed for all their help with this. I would still be screwing around with the piston wristpins by now if it wasn't for those guys.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Finally some love for the AWM.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Feb 27 2005
    North Wales, PA
    nice pics man. i didn't even notice you taking all of them. i like my white jump suit. i have to steal a couple more from work tomorrow. that one is trash...hahah i had duct tape holding it together.
    Oct 29 2005
    10speed
    San Francisco, CA
    did you guys hone and re-ring or no? and what was the reason for pulling the whole block out?
    - Clint
    Feb 27 2005
    North Wales, PA
    re cross hatched and reringed. all new seals and bearings. the motor was a bit low on compression and wanting to make sure the gt28rs had a healthy home.
    Apr 10 2007
    Eastern PA
    Quote Originally Posted by Poopie View Post
    The duct tape gives it character
    Pulling/Putting in the clutch/flywheel is also a 15 minute job with the engine out versus doing it while the engine is in the car which takes forever.
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    i like your style !!
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Senior Member Three Rings theskuh's Avatar
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    What did you use to re-cross hatch? Ball hone?
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Quote Originally Posted by theskuh View Post
    It's a drill attachment you can get at Harbor Freight, my new favorite store.
    Apr 10 2007
    Eastern PA
    lol, Aaron got you hooked. I love that place too. I always spend way too much when I'm there though.
    Jan 25 2006
    A4 2.0T
    MD
    Good work guys. Have you tested the compression after the build?
    What was the compression before?
    Apr 10 2007
    Eastern PA
    I just completed the first 50 mile run. I'm going to check the compression after I put another 100 miles on it just to make sure all is well.
    My compression before was:
    Cylinder 1 = 168
    Cylinder 2 = 145
    Cylinder 3 = 150
    Cylinder 4 = 165
    Veteran Member Four Rings 94jedi's Avatar
    Dec 07 2004
    Oly Platform, Pendlay bar, bumpers, squat rack, rings, Prowler
    Ocean Shitty Maryland
    damn, you guys are bad ass to do that in a weekend. My hat's off to the three of you!
    The harder I practice, the luckier I get.
    - Gary Player
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    X2
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I like your style.
    Quote Originally Posted by GetBoosted84 View Post
    SO much easier. That is why I pulled my trans out with my engine when I swapped my engine.
    How's compression look at 50miles? I presume you properly broke the rings in. Good deal! Glad to see another successful build/rebuild.
    -Doug
    Jan 21 2006
    6MT BT Avant Ti
    RI
    How many original miles on the motor before the rebuild? Did it feels strong with the lower cyl 2 compression?
    Apr 10 2007
    Eastern PA
    I'm not sure, I'll have to check tonight or tomorrow to see where it's at to see if it gets any better after another 100 miles of break-in.
    Quote Originally Posted by nebone22 View Post
    Just hit 92k miles. It actually felt pretty strong although I could notice a slight drop in performance from when I first started boosting at 23 psi.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    That was one of the things I did when changing the oil while breaking in my motor. I have four sets of compression results for the first 2500miles. Had perfect compression 30miles in. Told me I broke the rings in properly. Never lost any oil after 30miles. I lost some within the first 5miles but that was expected.
    -Doug
    Apr 10 2007
    Eastern PA
    I definitely need to check it tonight now. I'm excited to see my compression be where it should be so I can slap a new turbo on there and get some real power out of this engine.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Where did you buy the rebuild parts from? Can you post specs on which rods, bearings and piston rings you used?
    Apr 10 2007
    Eastern PA
    Parts Required to Build a AWM Engine:
    Engine:
    * 1 x Head Bolt Set $19.95 - From PureMS (Link)
    * 4 x Piston Ring Sets $35.95 - From PureMS (Link)
    * 1 x Rod Bearing Set $43.95 - From PureMS (Link)
    Gaskets:
    * 1 x Head Gasket Set $94.95 - From PureMS (Link)
    * 1 x Oil drain line gasket $2.79 - From PureMS (Link)
    If you are building your engine you may want to also pick up a timing belt kit while you are in there. I opted not to since my timing belt is about 8-10k miles old.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Are the rods 144x20mm or 144x19mm?
    Apr 10 2007
    Eastern PA
    19mm. AWM engines got screwed over with the smaller wristpin. You could always get a set of AEB pistons and go for the 20mm wristpin rods too but I decided not to for the power goals I am going for.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Yea, so I've heard but the pistons are really expensive to replace. So the correct rods 144x19 mm are $379.99
    Jan 21 2006
    6MT BT Avant Ti
    RI
    This is coincidence but your build is precicely what I had in mind for a while now. I might not rush into a stage 5 but definitely stage 4 w/ 15 lb flywheel. Must feel like a brand new car now.
    Apr 10 2007
    Eastern PA
    Great minds think alike :-)
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Just like the B6 AMBs.
    You have no idea. The car feels SOOO much better. Even though I am still breaking it in and not in boost I am enjoying every minute of it. I would highly recommend the stage 5. It's definitely streetable. This is my daily driver and I am loving it.
    My 2.0 feels so much smoother running than my old and tired 1.8. Glad to see you are happy.
    -Doug
    Jan 21 2006
    6MT BT Avant Ti
    RI
    This way we'll never know how many miles our motors can originally do. Who wants to see that tho.
    Jan 25 2006
    A4 2.0T
    MD
    Those purems prices are great.
    Apr 10 2007
    Eastern PA
    Yeah, they were the cheapest place I found for everything I needed. And integrated engineering wouldn't price match PureMS so they lost out on a bigger sale.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Check out this price on piston rings. MJM
    They also sell the ARP head bolts w/ tool for $150.
    Did your rods come with ARP rod bolts and nuts?
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Why spend $150 on upgraded head bolts when stock head bolts at $19.95 works just fine even while making 500+whp. So unless your looking at pushing 30+psi and making 600+whp it just really isn't something that needs to be upgraded.
    Dec 12 2006
    Charlotte,NC
    you mike, frankie on vortex is running the stock head bolts over 30psi and 707whp
    MK4 GTi 1.8T converted to AWD
    New 1/8th mile 7.36@102mph-27psi 93 octane, no meth
    New build times 23psi pump 11.9@126mph-96mph in the 1/8th
    04' A4 1.8t frontrak converted to quattro, was RWD for a lil now its quattro finally
    2011 JSW Tdi 6speed manual
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Quote Originally Posted by O2VW1.8T View Post
    heard autoextreme lifted one though...
    Apr 10 2007
    Eastern PA
    [QUOTE=nebone22;2784725]Check out this price on piston rings. MJM
    Good find on the rings... thats cheap! Too bad they are out of stock.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Putting any miles on it?
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Quote Originally Posted by 317ssayzarc View Post
    Did Marc's engine get messed up or anything? Was this on the drag car?
    Jim
    I Do Werk.
    Apr 10 2007
    Eastern PA
    I just completed the 100 mile run (did 40.2 before this). I am going to change out the oil, check the compression and do another 500 and see how it goes. Engine is feeling great but I keep getting a SAI code. I need to double check the hoses for that silly thing.
    Oct 30 2006
    B8 A4 Avant 6spd
    Very nice build up thread. How does the stage 5 feel? Is it okay for everyday driving?
    -18 718 GTS
