Results 1 to 7 of 7
    Established Member Two Rings midnyite's Avatar
    Jun 28 2007
    Have you heard of this before?
    Recently had a misfiring problem with my car.
    It was misfiring only in banks 1,2,3 basically the whole passenger side.
    Tried switching over the ICM and it still misfired in the same banks.
    Then my mechanic said maybe the engine was not properly grounded and was causeing a short?? never heard of such a thing. So he ran a wire on that bank and grounded it to another part of the engine bay on the chassis.
    And now the problem has gone away.
    Is this pure coincidence or did he actually do something?
    I have tried to beat the shit out the car to get it to misfire again to prove him worng but damn wont misfire anymore.
    Someone tell me i am crazy..
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: Have you heard of this before?
    these cars are finicky with grounds
    i had to take my main engine ground of 3 times or so just to clean it and reinstall it because i had charging problems and problems with sensors near the ground (oil level/temp sensor) and once cause my starter stopped working..
    all problems were fixed by just cleaning and reinstalling the ground
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    would terminal grease solve the problem of repeated cleanings of the engine ground?
    ThorTechnik.com
    Veteran Member Four Rings S4 John's Avatar
    Sep 19 2006
    The Man Cave
    where is the engine ground?
    //NEVER FOLLOW
    B5 S4 Avant - Nogaro Blue - TTE550 - ETSPEC
    8J TTRS - Panther Black - United Motorsport
    8V RS3 - Mystic Blue - TTE700 - Unitronic
    Feb 28 2007
    chicagoland
    right by the passenger side engine mount.
    Nogaro 01 s4
    620whp 93octane
    Feb 28 2007
    chicagoland
    Quote Originally Posted by S4evr View Post
    i put grease on it the last time.. havent had issues at all since
    i might add some more grounds just to combat any future issues
    Nogaro 01 s4
    620whp 93octane
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Bad ground can cause a lot of troubles of any kind. I just fixed a truck that the cabin ground has burned b/c of thunder that fell on cab and engine died. Engine ground was still in good shap tho. But cabin could'nt link with engine via datalink sae j1939. Took a while to find ithe trouble.
