Results 1 to 7 of 7
    Jan 17 2006
    Cali
    Want to make my own oil feed line for a K04
    But in order to do this I need to know the size of the fitting that goes into the turbo and the size of the fitting on the other end. I want to to screw directly into the turbo, I would convert it from whatever size to -6AN the do the same on the other side.
    So, anyone know the sizes of those fittings?
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    Re: Want to make my own oil feed line for a K04
    why? the stock one works fine?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    -6AN is bigger than stock, but I don't think it would help anything really. Unless you plan to run an additional cooler inline.
    I can check at work tomorrow. I have the old fittings out of my stock K03.
    Jan 17 2006
    Cali
    I want to replace is as I think it's slightly crimped and I am guessing making a new one will be cheaper than buying a replacement. Also, -6AN was a shot in the dark, I know it's bigger but -4AN or -3AN is a possibility.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I wouldn't go w/ a -3AN, I believe that would be smaller than stock. A -4AN would be fine. You don't need to feed it that much volume anyways.
    I could be wrong, I hope somebody that knows more about AN fittings and sizes than me chips in.
    I know we used -4AN to route 150+ worth of N20 on a couple of cars w/o an issue. But that's about the only thingk I've ever used it for.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Everyone uses -4 line for the BT/BAT line kits.
    Oct 06 2004
    Minnesota
    Ill sell you a stock line if you really want something to install...
    Instagram r_michals
    '12 Q7 TDI- Glacier White
