Originally Posted by
UGwagen
Isn't that a Stage 2+? I haven't heard too many good things about the iron-sintered pucks version (the "+" in 2+) but, the "puck" type isn't really known for long lasting durability durability.
Yes, that's the Stage 2+ I haven't had any problems with it yet(keyword) and I've put on almost 14K since I installed it(IIRC). This is with weekly AutoX for 3 months and a handful of 1/4mi runs, as well as daily driving.
SPEC claims it to be about similar lifetime to OEM when driven normally, obviously they aren't going to claim a lifetime under heavy abuse.
aaronamerica
your right, spec told me the same thing but it's no way the clutch would fit in the correct way, so this must mean I have the wrong flywheel for this application, do you have pics of your flywheel too?
What bolts were you using to hold the F/W to the crank? The ones SPEC Supplied?
Here's a pic of it on the table and being installed. I ran into an issue installing mine as well, but it turned out to be my own stupidity or lack or resourcefulness that got me into trouble. Not the same situation you were in.
I used the Billet Steel 16 lb F/W. The hub of the disc should fit into that machined bowl in the F/W w/o any issues. If you used the incorrect bolts it's possible that it didn't fit. I know it's a tight tolerance between those bolt heads and the hub b/c I measured it for some odd reason at one point.
