Well, my car has been running great lately, until the past couple of days. I noticed last night that it was idling a little low on startup, especially after I gave it a little rev, it would drop real low, and slowly climb back up.
Now, today, I was driving back from the gym, hit boost, everything's fine. I come to a stoplight, the car idles so low it almost stalls out. The vaccuum at idle was reading somewhere around -11 or so. It normally sits around -20. Now I tried hitting boost and it's around 6 or 7 psi, so I'm assuming the car is in limp mode because of a boost leak. However, now the idle is fine, I start it up, it idles fine. I wait 5 minutes, start it up again, and it idles like shit again. Vaccuum is back to around -11 to -13. I checked the intercooler pipes, they look OK. I did a visual check of all the boost hoses atop the engine and couldn't find any issues. I checked all the fuses, everything's OK, engine control unit fuse is fine.
I don't have a VAG com so I can't check the codes. Basically I want to know any common spots/hoses to check for now until i can get my hands on an air compressor to do a leak test or a VAG com.
I have a samco TBB, and F-hose, and they are both fine, so they can be ruled out.
Any suggestions?
